Continuing the discussion from PMS has stopped doing hardware transcoding on Intel UHD 630:
Server Version#: 1.25.8.5621
Player Version#: Plex for iOS v8
I wanted to start a new post to see if anyone has seen anything similar. When plugging a monitor into my thunderbolt port and having that as my primary display hardware transcoding started to fail with an error of
Mar 17, 2022 20:25:17.019 [6280] ERROR - [Transcoder] [h264_qsv @ 0252e680] Error initializing an internal MFX session: unsupported (-3)
Mar 17, 2022 20:25:17.019 [6280] ERROR - [Transcoder] Error initializing output stream 0:0 – Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Following the steps in How to use integrated graphics for Plex transcoding – erik.ellsinger.me it now works again. However Windows still says Plex Transcoder is using GPU 1 (RTX) but windows shows both GPU’s in use. Is that common? Can I tell which GPU is actually used?
Plex Media Server Logs_2022-03-17_21-38-53.zip (978.6 KB)
