IOS notification sounds
I am getting the notifications on my iPhone lock screen but I don’t get any sound. Is this normal?
Many thanks in advance
Do you have sounds enabled in the iOS notification settings for Plex?
From No Text or Message Notification Alerts or Sounds on iPhone? Fixes - AppleToolBox
Try These Steps to Fix Missing Text Message Notifications or Sounds
  • Check if your notifications are stacked together (for iPadOS and iOS 12 and above)
  • Make sure Deliver Quietly is not turned on for the app (for iPadOS and iOS 12 and above)
  • Check that your mute switch isn’t on
  • If you pair with an Apple Watch, notifications often bypassing the phone and go directly to your watch
  • Look through your contacts and ensure that you have not set their text or ringtone to None–if so, update it to a sound you like
  • Select a Text Tone or Change your selected text tone
  • Look at your Date & Time and choose Set Automatically
  • Change Notification Banners to Persistent
  • Make sure Do Not Disturb is off
  • Turn off Bluetooth or check your BT connections
  • Reset your network
  • Update to the latest version of iOS or iPadOS. New iOS/iPadOS versions fix a bug that prevented missed calls from appearing in the notification center
some of those seem a little odd… but they might be worth a try
Thanks, I will give them a try. I will try turning off Bluetooth on the app first
