somehow i can not get the remote function of the iOS app working. I tried rasplex 0.1.36 and 0.1.37.
The Rasplex client is in the same WiFi network as the iPhone. The server is is connected via cable.
If i start the OSX Client in the same WiFi network it gets listed in the client list and i can use the iOS remote.
Is there a way to fix it?
Having the same problem here too
I don't know how but it seems to be fixed. I installed v. 0.1.35 and updated to 0.1.37 using the RasPlex updater. I am also using a different WiFi Dongle (RTL8191SU, didn't work with 0.1.35 and 0.1.36).
I do not think that there is a connection to the new iOS update since the RasPlex is now listed in the client list (192.168.178.26:32400/clients).
The only thing not working yet is browsing on the iOS App and starting a movie from there, but that is not working for any client (OSX/Windows/RasPlex) since the new update.
No joy for me with with a fresh install of 1.35, 1.36 and 1.37. Also tried the upgrade 1.35-1.37. I am running the Pi on a wired network, and iOS can see Plex running on my Mac
i guess you restarted your server already...
Yeah I have restarted the server. It seems the fix was an entire network restart, I have a few switches / repeaters etc in my house and there must have been a conflict, I tried restarting individually but it didn't fix it. Had to restart everything and start the network router first, get everything up and running then turn on the Pi. Hope that helps someone else!
