Kicked from network?
Hi guys!
First, I apologize for my bad english.
Second, i really like the Rasplex project, i'm following it for a while now and i donated to Dale.
Here is the problem: i installed rasplex on SD by the installer for mac.
When i connect it to my tv en to the network it boot and opend the "homescreen" i saw the time set in the left upper corner, nothing wrong...
But when i try to use the remote on the iOs app, my ios app is doing weird things. It is freezing, or sometimes it is crashing.
When i try to use internet on my iphone, it won't work. When i power off the raspberry my internet is back on my iPhone and my iOs plex app is working correct.
The raspberry is connected to a router that is in bridge mode (linksys by cisco E4200 v1), that one is connected to my main router (linksys by cisco EA6500).
So when the raspberry is connected to that bridge router, i cant use that router anymore. It is like it is kicked from the network.
When i connect the raspberry directly to my main router there are still problems. I can't control it by my iOs app, again crashing or freezing.
By both of the routers i can only try it once, becouse after disconnect and connect the power it won't boot anymore. It still says: Now Loading...
I think it's becouse it isn't connected to the network anymore..??
I know it is a stange story, but my AppleTV 2 with Plex is working great, so it can't be my network right?
I also tried a other SD card and the windows installer. The same problems...
Who can help me?
This was an issue fixed back in 0.1.25. What version are you on?
0.1.32
