iPhone v's Android Pinned Libraries
Why when i try to set friends up with my Plex on their phone iPhone libraries are all pinned but Android are not . To make it even harder for Android users the app is so sensitive my fiends find it hard to pin all my libraries without having to go back to “More” to finish pinning them. Please fix the Android app so all libraries are pinned by default, i have about 30 libraries to pin and with the app being so sensitive it is very off putting.
I’m not really sure what you mean by sensitive. Is it not letting you hit Done?
Instead of pinning from more menu they can go to menu at top right of home screen next to the search icon and choose the Reset Customization. This will present a list of libraries and sources they have access to. By default everything is checked but they can uncheck things they don’t want. Pinned
Hi , thanx for the reply, I will try this next time . Regarding the sensitivity , it seems that when you try to hit the pin icon quite often it will take you back to the home page and you have to navigate back to the edit page again, i’m not sure if its because of a miss tap or whether the app has a bit of lag and tapping each icon too quick but very rarely can my friend’s pin all my libraries without this happening , hopefully with your solution i won’t have to do this with them , seems strange that iPhone have this already by default
