Will Plex work with this model Hauppauge device? My TV antenna won’t pick up my Fox local channel and need a cable recording device instead. I’d like to record to PLEX if it is compatible.
WinTV-DCR-3250
a triple tuner CableCARD receiver
http://www.hauppauge.com/pages/products/data_dcr3250.html
This post is 2 years old. Has anyone any new information on this device? Hauppauge WinTV-DCR-3250 supported?
if it aint listed @ https://support.plex.tv/articles/225877427-supported-dvr-tuners-and-antennas/
and there isn’t any newer info found in the forums, then I would suspect it simply isn’t supported.
hdhr has some cablecard compatible tuners, but everything depends on whether your cable provider broadcasts in the clear or not.
system
Closed
September 29, 2019, 8:49pm
3
