Server Version#:
Has anyone with this model TV gotten UNO??
Server Version#:
currently looks like its in beta you can side load it here
https://forums.plex.tv/t/plex-3-109-2-for-samsung-fhd-devices/443584
I’m familiar with sideloadig apps on an Android device, but not so much with TVs… hmmmm
it’s easy. it lists all the steps if you just click the link.
all you do is unzip the files to the right folder on a usbkey and insert it in to your tv. I did it for my bluray player. just make sure to remove the usb after or it will keep reinstalling it every time you turn on your tv.
The H model is pre-2016, the updates will not be going to those devices.
I’ll give it a look-see, thank you very much!
Thanks a shame, however thank you for the info and help!
Thanks @Can0nTV! @sLumpy I am attempting this on my Samsung 58" #UN58H5202, however, the TV recognizes the USB drive is inserted, but it’s not treating it as an installer, but instead just exploring the files on the USB. ANy thoughts?
This installer only works for 2016+ devices, so the sideloading won’t work.
