Hello everyone!
We’re excited to announce a preview release of the TV app for Samsung devices. This version includes the new UNO design. For more information regarding UNO including what it is and how to enable it, please see this post here.
This release is for UHD Samsung devices running on Tizen 2.4 or higher (2016+).
How to Install the Preview
The build is not available on the Samsung App store yet, so it will need to be sideloaded onto your TV directly.
You will need:
- A USB stick with at least 25 MB free
- The preview release (3.103.1) .zip file
Instructions:
- Uninstall the existing Plex application
- Download the .zip release above
- On your USB stick, create a folder called
userwidget - Unzip the contents of the .zip file into the userwidget folder you just created
- Turn on the TV
- Plug in the USB drive into your Samsung UHD device. Installation should start automatically.
- Run the App from your Smart Hub, or from the App store.
Enabling UNO:
- In the TV app, go to Settings → Main.
- Enable
Preview the new Plex experience
Changelog
You can view the changelog here for the changes outside of UNO.
Providing Feedback
If you encounter any issues or have constructive feedback regarding the new UNO UI, please create a topic in the smart tvs category with:
- Description of the problem
- PMS Version:
- Device Model:
- Tizen Version:
- App Version:
- PMS Log
- Turn on “Log to Media Server” under Settings -> Privacy so we can see the Samsung logs as well
Thanks!
