Hi everyone,
Since a recent update I have a “More” menu on the left side of the home page when I first open Plex in the browser. Is there a way to shut that off and always show all?
Thanks,
PCNerd
Hi everyone,
Thanks,
PCNerd
You cannot shut it off but you can pin all your libraries and click Turn on settings sync in the General Plex Web settings. That way, all your Plex Web sessions should automatically show all your libraries in the main navigation (until you add new libraries… then you need to pin those too).
Well crap… I have 2 servers setup right now till I get it setup on linux then remove the first and the second won’t show unless I hit that More option. Real PITA when going in and out while setting this up. Can’t pin a server I don’t think.
Thanks tons for the reply Tom. Have a good one.
I suppose you misunderstood something…
There’s no limitation on how many different libraries from how many different servers you pin to your navigation.
Plex has just moved away from a model where you access servers individually.
No I get it…
was just hoping the More option was removable because I like the defined look of that rather than a bunch of pinned items. All good Tom.
Thanks again.
Hit the ‘Hamburger’ and collapse that rascal.
It’ll stop annoying ya as much… (‘More’ vanishes)
Juice, You are outstanding. Done and Solved.
Thanks to all,
Charles.
