Is there a way to manually sort collections?
Server Version#: 1.25.8.5621-7a6fed0cf, and 1.25.7 something.
Player Version#: Web 4.76.1 , App 1.41.0.2876-e960c9ca, and an earlier app.
I’m trying to get the collections feature to work with custom sort orders so I can put some TV shows in different orders, like in-universe chronological vs aired date. But the sorting is extremely buggy.
Dragging saves the order until I back out, then it reverts. It seems to move the last item moved to the front of the list. So I moved every other episode in front of the one I was moving, which worked. But I needed to move one from the end of the list. Finally got it moved, but now my first episode is off by two places, and I can’t seem to make it move anywhere at all through any means.
I updated to the newest server version, which supposedly fixes the problem, but it’s not working. I’ve tried the Windows app (2 versions, including the most recent one) and the web app. Nothing works.
Is there a file I can edit to manually set the sort order for the collection?
