I’m using Plex on Windows 7 to stream movies from a PC to Firesticks on remote TVs. All content is stored locally, nothing streaming and I have a large library of movies. The software works well for my needs. Just wondering if there is a way to set some sort of default behavior so when I first start Plex and open the movies folder the first thing I see is the same folder structure that exists on my computer. I can get there through several clicks, but it seems like a waste to have to do that every time I use it. Thanks.
As long as remember selected tab is enabled in settings it should stay on whatever view you left it.
