how can I explain this. I have a series in a library with all of my other movies. I want to be able to keep them seperate from the movies. Organized more less. It’ll show that series with the thumbnails only rather then throwing all the series thumbnails in with all the movies.
Would I just create another library and name it the name of the series?
Okay so, I created a new library called TV Shows, and I put what I wanted into that library. Now how do I remove the duplicate ones in my movies library without it physically deleting my videos?
Or is there a way to copy all the ones from one library to another?
Remove them from the movie library folder they are in and put them in the TV show library type folder.
Be sure you structure and name the TV Show library folder per Plex naming conventions.
I don’t see remove, only option is if I go into server setting and click on delete library, all that will do is delete all the movie files from my HDD.
Nooo…
Remove them or add them to the folders on the HDD that the library points to when you add folders to the library.
IE:
Go to the movie folder where the TV shows are now that the Movie library is pointed too. Remove them from that folder.
Go to the folder the TV show library is pointed to and put them in there.
I do not know any more clear way to express what I am trying to explain to you…
NOT via Plex but from your OS level…
Don’t delete your library, If you do Plex will need to rescan all again, however the movie files will not be deleted by deleting the library…
