Server Version#: 1.27.2.5929
Player Version#:9.5.0.33501
I recently got a new phone running Android 12 that won’t play anything in Plex when using mobile data. I can see everything on continue watching and in my libraries just none of the images load but when you try to play anything I just get Something Went Wrong.
Now if I put that sim card into my old phone running Android 9 I can play anything using mobile data and the images for things in my library load as normal.
Playing things over WiFi is not affected at all.
I can provide logs, just tell is there anything I should be doing when getting them.
I’ve no problems with my Pixel 3A XL. However, sometimes device specific issues arise. Knowing make/model will help with problem replication & diagnosis.
A set of android logs that capture the problem would help as well.
Put the phone on the mobile network.
Launch the Plex app & re-create the problem.
Re-enable wifi
Pull the device log file, http://device_ip_address:32500 (settings → help & support → debugging)
Save as a .txt or .log and post to the thread.
See Android Logs support doc for additional details.
