I watch lectures through Plex on PS4.
My preference watching lectures is to speed up video somewhere between x1.18 and x1.45
For normal tv and movies I usually increase speed by 1.04 or so.
Any scope for this option to come to Plex, specifically the PS4 app version?
I have a solution that works in chrome browser that I posted elsewhere on the forum, not PS4 sorry
but maybe it will be useful for your lectures. Hope it helps!
To anyone searching for a solution, there is one, but not perfect. First you need to be using chrome and download the “Video Speed Controller” extension for chrome. Then you can watch sped up plex through the chrome browser by utilizing the plugin. I just tested it and it worked pretty good while on my local network (I couldn’t tell you about playback when away from home). Like I said, not perfect since it only works in the browser and specifically chrome (I haven’t researched other browsers because chrome is my main). It does work though and if you just are watching a lecture or something I think it would work great. Also, if you don’t care about watching in a browser you are good to go. Hope this helps anyone.
tl;dr
1.Use Chrome
2.Download “Video Speed Controller” extension
3. Boot up Plex Media Server in Chrome
4. Use extension to watch at any speed you desire
