I've got a bunch of unfinished episodes on season 11, but Plex jumped ahead to season 14 and shows episodes from that season on Deck instead.
If you mark the unfinished ones as unwatched then it should jump back to the first unwatched episode.
They are all marked unwatched. Several from season 11, ALL of season 12, ALL of season 13 are all marked unwatched.
It's showing season 14 as the next episode anyway. Is there no way to reset this?
but ....
Am I missing something? I haven't watched a single episode of season 14 ... ( nor 12, nor 13 )
Only thing I can think of is to mark all seasons as watched. That would clear them. Then mark all as unwatched and then finally mark the episodes you have seen as watched. That should correctly update the ondeck section. Strange that its happening like that though.
Hm, That's a bit of a PITA. Hopefully it will work.
Ha ha pita. Never seen that one before
but you’re right it is. Fingers crossed it works for you!
Worked, and it was not a pain at all. Just marked all of S14 watched through the web interface. Then marked it unwatched. That got everything restored. Thanks for the tip, it was a good idea ;)
Cool. Glad it worked for you
2018, and I’m having the same issue… I want to start a show from S1E1… So I played all, unplayed all and BAM S6E1 On Deck…
I think there is a “You want to play the latest seasons” assumption somewhere in the background…
