Issue running plexconnect
I work according to the tutorial but when I run the file PlexConnect.py I got error:
    XML = getSectionXML(PMS_list, {}, '')
NameError: name 'getSectionXML' is not defined
these the all command output:
C:\Program Files (x86)\PlexConnect-master>PlexConnect.py
20:25:40 : *** local Server/Sections
20:25:40 __main__: ***
20:25:40 __main__: looking up Plex Media Server
20:25:40 __main__: Sending discovery message: M-SEARCH * HTTP/1.0
20:25:40 __main__: Received data from ('10.0.0.6', 32414)
20:25:40 __main__: Data received:
 HTTP/1.0 200 OK
Content-Type: plex/media-server
Resource-Identifier: 7c6dc1ffd0043baf23d75286b3d7a4f751f66095
Port: 32400
Updated-At: 1398188703
Version: 0.9.9.7.429-f80a8d6
20:25:41 __main__: GDM: Servers discovered: 1
20:25:41 __main__: PlexServer 10.0.0.6:32400
Traceback (most recent call last):
  File "C:\Program Files (x86)\PlexConnect-master\PlexConnect.py", line 815, in
any idea?
thanks,
Cfir.
The referenced line (815) is NOT in PlexConnect.py, but PlexAPI.py. It's part of the early test code for running/testing the PlexAPI functions on their own.
I have two issues with your report...
- my test code is out of date. :-(
- you somehow swapped the content of PlexAPI.py into PlexConnect.py. Try to re-download the sources (or unzip again...) to fix that.
all working, thanks
