Issue with certification
Hi guys,
After moving I am experiencing a lot of issues with the plex certificate. A lot of the devices are unable to connect securely now. Is there a way I can fix this?
Thanks,
Max
@MaxM1999
“Cannot connect securely” also means “not found/ no reply”.
I looked at your account.
I found several abandoned (not used in a long time) servers
I removed them to avoid confusion by the clients.
Now, only your current server remains
Please restart the server
then restart the player devices
Hi @ChuckPa ,
Thanks for your quick action. I restarted the server but the issue is still there.
Could you maybe advise another solution?
FYI: There is a option to allow insecure connections. When I do that the media does play.
Thanks,
Max
