I have an HEVC H265 HDR10 EAC5.1 Dolby Atmos movie encoded at CBR 60 fps. When I try to play it back on ATV, this is very choppy and not watchable, but it works great with emby and infuse as well as the Plex player on MACOS and the beta player on ios and ipados. Is there an issue with the ATV here? Why is there an issue?
Here is one which is not even HDR10 which does not play well, choppy frame rate when on the ATV and play smoothly on Infuse and emby:
General
Complete name : C:\Users\admin\Desktop\Brillantissime (2018).mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/iso2/mp41)
File size : 14.6 GiB
Duration : 1 h 26 min
Overall bit rate : 24.2 Mb/s
Frame rate : 60.000 FPS
Title : Brillantissime (2018)
Encoded date : 2025-08-12 17:55:17 UTC
Tagged date : 2025-08-12 17:55:17 UTC
Writing application : HandBrake 1.9.2 2025022300
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@Main
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 23.9 Mb/s
Width : 3 840 pixels
Height : 1 606 pixels
Display aspect ratio : 2.39:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.065
Stream size : 14.4 GiB (99%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : hvcC
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : ec-3
Source duration : 1 h 26 min
Bit rate mode : Constant
Bit rate : 320 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 198 MiB (1%)
Source stream size : 198 MiB (1%)
Title : Surround
Language : French
Service kind : Complete Main
Default : Yes
Alternate group : 1
Dialog Normalization : -31 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
Let me know which logs you want and will post them as soon as you reply…
