Issue with TV shows metadata
Server Version#: 1.15.8.1163 (Docker binhex-plexpass)
I recently migrated to Unraid and i setup a new server from scratch using the binhex-plexpass docker image
There was no issues with adding my existing movies, and new movies added since the server is running are fine
The problem is with TV shows. I have two TV show libraries. The first one has correct metadata after the initial adding. However the second library does not get metadata. I also noticed that new TV shows coming to the first TV library don’t have any metadata
In my plex media scanner logs i am seeing the following errors when trying to refresh meta data in the second TV library
|Jun 06, 2019 15:13:18.675|ERROR|Error issuing curl_easy_perform(handle): 28|
|Jun 06, 2019 15:13:18.675|ERROR|Error parsing content.|
|Jun 06, 2019 15:13:18.675|ERROR|Error parsing XML: Error parsing file.|
I have tried so far.
Refresh metadata on the second TV library
Delete the second TV library and add again
Setup a new plex server docker and try to add the library.
Movie metadata seems fine, so could this be an external problem with TVDB?
Any ideas would be greatly appreciated!
Thanks in advance
Update: I have just edited my second TV library to use The Movie Database agent instead of TVDB and now metadata is shown correctly. Is there a problem with TVDB at the moment?
