Issues accessing libraries/folders on QNAP PMS
I use Plex server on my QNAP…
PMS : 1.19.1
I have the same issue.
  • https://app.plex.tv/desktop -> I see “Home” but cant reach my server/folders
  • https://ip_address_of_server:32400/web/index.html -> Steel loading, cant reach localhost
Troubleshooting Plex on Windows is different from Plex on QNAP. Hopefully somebody will answer your post in the QNAP section.
Not trying to shut you down. Just that other than “make sure Plex Media Server is running” the troubleshooting steps would most likely be different.
You might try pulling the log files and attaching them to your QNAP post. Since you can’t get to the Plex server via a web browser, login to your QNAP, navigate to the Plex logs folder, zip the entire folder, and attach it to the thread.
See support docs for help in locating the log file folder (I’ve never used a QNAP):
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
Mod-Edit: moved to a separate post; please don’t hijack other threads with different issues / use cases.
On log file :
Jun 10, 2020 16:25:22.708 [0xb46f6000] INFO - OCSP: Loaded a stale response from cache.
Jun 10, 2020 16:25:22.708 [0xb46f6000] INFO - OCSP: Couldn’t install the cached response; fetching from network.
Jun 10, 2020 16:25:22.709 [0xb46f6000] DEBUG - CERT: Installed intermediate certificate.
Jun 10, 2020 16:25:22.709 [0xb46f6000] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Jun 10, 2020 16:25:22.710 [0xb46f6000] ERROR - HttpServer: Error binding acceptor: Address already in use
Jun 10, 2020 16:25:22.710 [0xb46f6000] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address already in use
Jun 10, 2020 16:25:22.772 [0xb46f6000] ERROR - Error: Unable to set up server: listen: Address already in use (xxx)
xxx = my private key ?
On holder log file :
Jun 02, 2020 21:34:10.387 [0xb367e460] DEBUG - EventSource: Failure in ReadData (2 - End of file).
Jun 02, 2020 21:34:10.388 [0xb367e460] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
Jun 02, 2020 21:34:10.388 [0xb367e460] ERROR - EventSource: Retrying in 15 seconds.
Jun 02, 2020 21:34:25.388 [0xb3390460] DEBUG - EventSource: Resolving 176.58.107.84 port 443
Jun 02, 2020 21:34:25.388 [0xb3390460] DEBUG - EventSource: Resolved 176.58.107.84 to 176.58.107.84
Jun 02, 2020 21:34:25.404 [0xb367e460] DEBUG - EventSource: Failure in Connect (111 - Connection refused).
Jun 02, 2020 21:34:25.404 [0xb367e460] ERROR - EventSource: Retrying in 30 seconds.
Jun 02, 2020 21:34:55.404 [0xb3390460] DEBUG - EventSource: Resolving 176.58.107.84 port 443
Jun 02, 2020 21:34:55.404 [0xb3390460] DEBUG - EventSource: Resolved 176.58.107.84 to 176.58.107.84
Jun 02, 2020 21:34:55.419 [0xb367e460] DEBUG - EventSource: Failure in Connect (111 - Connection refused).
Jun 02, 2020 21:35:00.419 [0xb367e460] DEBUG - EventSource: Stopping.
Jun 02, 2020 21:35:00.420 [0xb367e460] DEBUG - HTTP requesting GET https://plex.tv/services/pubsub/servers
Jun 02, 2020 21:35:00.434 [0xb3390460] DEBUG - EventSource: Stopping.
Jun 02, 2020 21:36:30.428 [0xb367e460] ERROR - Error issuing curl_easy_perform(handle): 28
Jun 02, 2020 21:36:30.429 [0xb367e460] DEBUG - HTTP simulating 408 after curl timeout
Jun 02, 2020 21:36:35.435 [0xb367e460] DEBUG - PubSubManager: Time to connect to 109.237.24.233 was 317 ms.
Jun 02, 2020 21:36:35.435 [0xb367e460] DEBUG - PubSubManager: Time to connect to 172.104.145.70 was 501 ms.
Jun 02, 2020 21:36:35.435 [0xb367e460] DEBUG - PubSubManager: Time to connect to 172.104.44.222 was 628 ms.
Jun 02, 2020 21:36:35.435 [0xb367e460] DEBUG - PubSubManager: Time to connect to 45.79.23.169 was 1274 ms.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Connection to 82.94.168.18 failed: Connection timed out.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Connection to 45.56.115.195 failed: Connection timed out.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Connection to 45.33.73.250 failed: Connection timed out.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Connection to 172.105.203.197 failed: Connection timed out.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Connection to 184.105.148.115 failed: Connection timed out.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Connection to 172.105.13.59 failed: Connection timed out.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Connection to 176.58.107.84 failed: Connection timed out.
Jun 02, 2020 21:36:35.435 [0xb367e460] WARN - PubSubManager: Current server (176.58.107.84) failed, we’ll switch.
Jun 02, 2020 21:36:35.492 [0xb367e460] DEBUG - EventSource: Stopping.
Jun 02, 2020 21:36:35.493 [0xb367e460] DEBUG - EventSource: Resolving 109.237.24.233 port 443
Jun 02, 2020 21:36:35.493 [0xb367e460] DEBUG - PubSubManager: Updating best host to 109.237.24.233.
Jun 02, 2020 21:36:35.493 [0xb3390460] DEBUG - EventSource: Resolved 109.237.24.233 to 109.237.24.233
Jun 02, 2020 21:36:35.494 [0xb367e460] DEBUG - PubSubManager: Updating best ping time for 109.237.24.233 to 317 ms.
Jun 02, 2020 21:36:35.494 [0xb367e460] DEBUG - EventSource: Stopping.
Jun 02, 2020 21:36:35.495 [0xb367e460] DEBUG - EventSource: Stopping.
Jun 02, 2020 21:36:35.496 [0xb367e460] DEBUG - EventSource: Stopping.
Jun 02, 2020 21:36:36.857 [0xb3390460] DEBUG - EventSource: Connected in 358 ms.
Jun 02, 2020 21:36:36.857 [0xb3390460] DEBUG - EventSource: Wrote data, reading reply.
Jun 02, 2020 21:36:52.014 [0xb367e460] DEBUG - EventSource: Read HTTP reply header.
Jun 02, 2020 21:36:52.014 [0xb367e460] DEBUG - EventSource: Failure in ParseHeader: HTTP/1.1 500 Internal Server Error
Server: nginx
Date: Tue, 02 Jun 2020 19:36:58 GMT
Content-Type: text/html
Content-Length: 186
Connection: close
nginx
Later :
Jun 02, 2020 21:51:50.639 [0xb3390460] DEBUG - PubSubManager: Time to connect to 139.162.158.105 was 370 ms.
Jun 02, 2020 21:51:50.639 [0xb3390460] DEBUG - PubSubManager: Time to connect to 45.79.128.184 was 988 ms.
Jun 02, 2020 21:51:50.639 [0xb3390460] DEBUG - PubSubManager: Time to connect to 184.105.148.116 was 1346 ms.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Connection to 45.56.115.195 failed: Connection timed out.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Connection to 45.33.125.156 failed: Connection timed out.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Connection to 139.162.75.196 failed: Connection timed out.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Connection to 109.237.24.233 failed: Connection timed out.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Connection to 172.104.44.222 failed: Connection timed out.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Connection to 172.105.97.53 failed: Connection timed out.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Connection to 82.94.168.18 failed: Connection timed out.
Jun 02, 2020 21:51:50.639 [0xb3390460] WARN - PubSubManager: Current server (45.56.115.195) failed, we’ll switch.
Jun 02, 2020 21:51:50.653 [0xb3390460] DEBUG - EventSource: Stopping.
Jun 02, 2020 21:51:50.653 [0xb3390460] DEBUG - EventSource: Resolving 139.162.158.105 port 443
Jun 02, 2020 21:51:50.654 [0xb367e460] DEBUG - EventSource: Resolved 139.162.158.105 to 139.162.158.105
Jun 02, 2020 21:51:50.655 [0xb3390460] DEBUG - PubSubManager: Updating best host to 139.162.158.105.
Jun 02, 2020 21:51:50.656 [0xb3390460] DEBUG - PubSubManager: Updating best ping time for 139.162.158.105 to 370 ms.
Jun 02, 2020 21:51:50.656 [0xb3390460] DEBUG - EventSource: Stopping.
No log file between Jun 02 and Jun 10.
I have the same issue. Did you manage to resolve this ?
Restart QNAP
I did it yesterday and it works. Thx
How this issue is possible ?
Because a process somehow was hanging, and occupied the port number, thus preventing a restart of PMS
