Issues Download X265 codec
Hey Team, still having issues downloading the x265 codec after the hash issue a few days ago, deleted the codec folder from my ubuntu PMS but when trying to download the x265 codec
attempting to download manually to the codec folder gives me a 403 forbidden error.
I also have this issue since upgrading.
I have manged to get some of the codecs and install them manually so x264 works but x265 does not.
https://downloads.plex.tv/codecs/e613bce-97f23d579c1001d8e9cc0d2e/linux-x86_64-standard/libaac_encoder.so
https://downloads.plex.tv/codecs/e613bce-97f23d579c1001d8e9cc0d2e/linux-x86_64-standard/libdca_decoder.so
https://downloads.plex.tv/codecs/e613bce-97f23d579c1001d8e9cc0d2e/linux-x86_64-standard/libh264_decoder.so
https://downloads.plex.tv/codecs/e613bce-97f23d579c1001d8e9cc0d2e/linux-x86_64-standard/libmp3_decoder.so
however the rest elude me. Running a filed that forces a re-code does not work if you cannot start the file.
yeah same issue, i can auto download the other codecs when i attempt to open a file that is encoded with them x265 is the only one that won’t download (doesn’t help when its the majority of my library)
managed to get it going jann, just run:
wget https://downloads.plex.tv/codecs/e613bce-97f23d579c1001d8e9cc0d2e/linux-x86_64-standard/libhevc_decoder.so
thanks for that, oddly enough I tried that as well but was getting a 403 error.
Seems to work now.
:smiley:
For anyone else who stumbles across this.
I used wget to put those (at the time of writing 5) files into your “config/Library/Application Support/Plex Media Server/Codecs/e613bce-97f23d579c1001d8e9cc0d2e-linux-x86_64” directory and chmod +x all of the .so files.
I am using the docker container. I had to chmod them and restart the container before they would work. your mileage may vary good look future questers
