Issues setting recordings on androidTV clients (CCwGTV)
Server Version#: 1.32.0.6973
Player Version#: 9.20.1.979 (0b42781)
Tuner Make/Model: Siliciondust HDHomeRun FLEX QUATRO
Model: HDFX-4DT
Guide/Lineup name: Plex Guide data
Using XMLTV?: No
Channel number/Name: All
Plex Media Server Logs_2023-04-24_18-25-24.zip (5.3 MB)
When setting a recording on an AndroidTV client, such as a CCwGTV, after the recording is set, you get no notification that the recording was successfully set, and worse still, you get sent back to the start of the guide.
When setting a recording for days in advance, this means that you will need to spend considerable time scrolling to the back to that point to continue setting more listings to record.
Other issues on the Android TV client include:
-Scrolling too fast will cause the guide to lock up, and you not to be able to move
-Long listings will prevent the icon showing that it is set to recorded will not be visable
-Random crashs that seem to occur with no obvious cause
-De-interlacing is very poor on non HD channels (575i) but good on HD channels (1080i) - BOTH ARE DIRECT PLAY THIS IS NOT A TRANSCODING ISSUE
These issues are not present in any other client in my experience
Many thanks.
