Issues with playback
i am trying to playback some movies/series on my vero4k running latest version of osmc(kodi) where plex plugin is installed as addon. Basically it doesnt work at all … movie starts … and got stuck immediatelly … why?
I can playback that movie under same user on ipad w/out any issue … but trying to do a playback on vero4k via plex plugin doest work at all … here are some scraps from logs… any idea where to stick?
Apr 06, 2020 02:03:07.927 [0x7f3969ffb700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 06, 2020 02:03:30.057 [0x7f39834cf700] ERROR - EventSource: Retrying in 15 seconds.
Apr 06, 2020 02:04:05.058 [0x7f39834cf700] ERROR - EventSource: Retrying in 30 seconds.
Apr 06, 2020 02:04:11.482 [0x7f3978dde700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:04:13.239 [0x7f397bfff700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:04:23.122 [0x7f3980cca700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:04:26.661 [0x7f395f7fe700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 06, 2020 02:04:26.661 [0x7f395f7fe700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 06, 2020 02:04:26.661 [0x7f395f7fe700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 06, 2020 02:04:26.661 [0x7f395f7fe700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 06, 2020 02:04:26.661 [0x7f395f7fe700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 06, 2020 02:04:26.661 [0x7f395f7fe700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 06, 2020 02:04:27.722 [0x7f395f7fe700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:11:29.996 [0x7f395f7fe700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:11:31.283 [0x7f395ffff700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:11:41.750 [0x7f3982cce700] ERROR - getaddrinfo(10-0-1-44.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -5
Apr 06, 2020 02:04:54.153 [0x7f3982cce700] ERROR - EventSource: Retrying in 60 seconds.
Apr 06, 2020 02:05:43.338 [0x7f395effd700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:05:49.106 [0x7f3969ffb700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:05:54.378 [0x7f39834cf700] ERROR - getaddrinfo(10-0-1-44.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -5
Apr 06, 2020 02:05:55.382 [0x7f3980cca700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 06, 2020 02:05:55.382 [0x7f3980cca700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 06, 2020 02:05:55.382 [0x7f3980cca700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 06, 2020 02:05:55.382 [0x7f3980cca700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 06, 2020 02:05:55.382 [0x7f3980cca700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 06, 2020 02:05:55.382 [0x7f3980cca700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 06, 2020 02:05:56.451 [0x7f39697fa700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:06:08.608 [0x7f3968ff9700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Apr 06, 2020 02:06:11.611 [0x7f3968ff9700] ERROR - Error issuing curl_easy_perform(handle): 28
Apr 06, 2020 02:06:26.616 [0x7f3968ff9700] ERROR - Error issuing curl_easy_perform(handle): 28
Apr 06, 2020 02:06:26.616 [0x7f3968ff9700] WARN - MyPlex: Updating device connections failed, retrying in 10 seconds.
Apr 06, 2020 02:06:40.233 [0x7f395f7fe700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:06:51.621 [0x7f3968ff9700] ERROR - Error issuing curl_easy_perform(handle): 28
Apr 06, 2020 02:06:51.621 [0x7f3968ff9700] WARN - MyPlex: Updating device connections failed, retrying in 20 seconds.
root@ronn-core:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs#
root@ronn-core:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs# systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-04-06 01:58:31 CEST; 9min ago
Process: 29882 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_AP
Main PID: 29886 (Plex Media Serv)
Tasks: 73
Memory: 742.2M
CPU: 2min 29.739s
CGroup: /system.slice/plexmediaserver.service
├─29886 /usr/lib/plexmediaserver/Plex Media Server
├─29914 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-e106a8a91/Framework.bundle/Contents/Resources/Ve
├─29967 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resource
├─30001 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-e106a8a91/Framework.bundle/Contents/Resourc
├─30031 /usr/lib/plexmediaserver/Plex Relay -p 443 -N -R 0:127.0.0.1:32401 -o StrictHostKeyChecking=yes -o UserKnownHostsFile=/var/lib
└─30084 /usr/lib/plexmediaserver/Plex Transcoder -codec:0 h264 -codec:1 ac3 -ss 450 -noaccurate_seek -analyzeduration 20000000 -probes
Apr 06 01:58:31 ronn-core systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Apr 06 01:58:31 ronn-core systemd[1]: Stopped Plex Media Server.
Apr 06 01:58:31 ronn-core systemd[1]: Starting Plex Media Server…
Apr 06 01:58:31 ronn-core systemd[1]: Started Plex Media Server.
Apr 06 01:58:43 ronn-core Plex Tuner Serv[29967]: Plex Tuner Service: Critical: libusb_init failed
lines 1-21/21 (END)
also find in log:
Apr 06, 2020 02:11:56.820 [0x7f39537f6700] WARN - NAT: PMP, got an error: Not Supported by gateway.
while playback on ipad is running even tho there are errors in log:
Apr 06, 2020 02:14:15.683 [0x7f73017fa700] ERROR - [PlexRelay] kex protocol error: type 7 seq 11
Apr 06, 2020 02:14:16.051 [0x7f7301ffb700] INFO - [PlexRelay] Allocated port 25453 for remote forward to 127.0.0.1:32401
Apr 06, 2020 02:14:19.358 [0x7f72fbfff700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 06, 2020 02:14:22.955 [0x7f72fb7fe700] WARN - QueryParser: Invalid field ‘promoted’ found, ignoring.
Apr 06, 2020 02:14:22.956 [0x7f72fb7fe700] WARN - QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Apr 06, 2020 02:14:22.963 [0x7f72fb7fe700] WARN - QueryParser: Invalid field ‘promoted’ found, ignoring.
Apr 06, 2020 02:14:22.963 [0x7f72fb7fe700] WARN - QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Apr 06, 2020 02:14:22.966 [0x7f72fb7fe700] WARN - QueryParser: Invalid field ‘promoted’ found, ignoring.
Apr 06, 2020 02:14:22.966 [0x7f72fb7fe700] WARN - QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Apr 06, 2020 02:14:31.164 [0x7f72fb7fe700] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
Apr 06, 2020 02:14:31.240 [0x7f7301ffb700] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
Apr 06, 2020 02:14:31.705 [0x7f7301ffb700] ERROR - [Transcoder] [h264 @ 0xf68e80] number of reference frames (0+4) exceeds max (3; probably corrupt input), discarding one
Apr 06, 2020 02:14:49.430 [0x7f72fb7fe700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
and afterwards on vero4k (kodi)
Apr 06, 2020 02:16:56.674 [0x7f72f9ffb700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 06, 2020 02:16:56.674 [0x7f72f9ffb700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 06, 2020 02:16:56.674 [0x7f72f9ffb700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 06, 2020 02:16:56.674 [0x7f72f9ffb700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 06, 2020 02:16:56.674 [0x7f72f9ffb700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 06, 2020 02:16:56.674 [0x7f72f9ffb700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 06, 2020 02:16:57.879 [0x7f72fbfff700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:17:12.883 [0x7f73247f4700] ERROR - Error issuing curl_easy_perform(handle): 28
Apr 06, 2020 02:17:19.699 [0x7f72f9ffb700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 06, 2020 02:17:23.547 [0x7f73017fa700] ERROR - Time value was negative, ignoring.
Apr 06, 2020 02:18:00.269 [0x7f72fb7fe700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
Apr 06, 2020 02:18:00.355 [0x7f72fbfff700] ERROR - Unable to find client profile for device; platform=Kodi, platformVersion=18.5, device=Linux, model=Unknown
also what exactly means:
Apr 06, 2020 02:29:19.013 [0x7f7321fef700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Hello,
is there anyone who can help on this? Its bit an urgent issue. :frowning: Thanks!
How urgent can playing a video file really be?
You need to give more information. XML details of the file, full logs, not what you deem relevant. Server and player versions.
hello, how can i do that… could you please advise?
ie XML details of file, full logs, …?
Server version is Version 4.22.3
how can i get client version- ? its plugin installed inside Kodi latest version on vero4k.
why i am constantly getting such an error in plex media server log:
Apr 07, 2020 00:02:48.281 [0x7f7321fef700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
^^^ any idea what is it?
thanks
@Flanders
so the plex plugin - addon version 0.2.0 , kodi version 18.6, current server version 1.18.9.2571
ok thats pretty nonsense … Plex pass owner … and no support at all, i dont know for what i paid.
also looks like plex-for-kodi is not supported anymore? So now plex is forcing me to buy new device? what a COMPANY.
is it possible to say whats going on from these logs?
Apr 20, 2020 00:03:40.921 [0x7f7323ff3700] ERROR - EventSource: Retrying in 480 seconds.
Apr 20, 2020 00:04:14.307 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:04:44.572 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:05:14.056 [0x7f7300ff9700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:05:44.588 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:06:44.587 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:07:14.356 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:09:14.165 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:09:43.886 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:10:13.554 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:10:43.915 [0x7f73217ee700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
Apr 20, 2020 00:11:04.822 [0x7f73247f4700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 20, 2020 00:11:04.822 [0x7f73247f4700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 20, 2020 00:11:04.822 [0x7f73247f4700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 20, 2020 00:11:04.822 [0x7f73247f4700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 20, 2020 00:11:04.822 [0x7f73247f4700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 20, 2020 00:11:04.822 [0x7f73247f4700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 20, 2020 00:11:04.843 [0x7f73247f4700] WARN - Streaming Resource: Bandwidth exceeded: 20796 kbps > 16000 kbps
Apr 20, 2020 00:11:05.491 [0x7f7300ff9700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 20, 2020 00:11:05.491 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 20, 2020 00:11:05.491 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 20, 2020 00:11:05.491 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 20, 2020 00:11:05.491 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 20, 2020 00:11:05.491 [0x7f7300ff9700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 20, 2020 00:11:06.361 [0x7f73217ee700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 20, 2020 00:11:06.361 [0x7f73217ee700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 20, 2020 00:11:06.362 [0x7f73217ee700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 20, 2020 00:11:06.362 [0x7f73217ee700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 20, 2020 00:11:06.362 [0x7f73217ee700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 20, 2020 00:11:06.362 [0x7f73217ee700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 20, 2020 00:11:06.362 [0x7f73217ee700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 20, 2020 00:11:07.058 [0x7f7300ff9700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 20, 2020 00:11:07.058 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 20, 2020 00:11:07.058 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 20, 2020 00:11:07.058 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 20, 2020 00:11:07.058 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 20, 2020 00:11:07.058 [0x7f7300ff9700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 20, 2020 00:11:07.115 [0x7f73237f2700] ERROR - [TranscodeOutputStream] Session appears to have died from under us
Apr 20, 2020 00:11:08.416 [0x7f7300ff9700] ERROR - ClientProfileExtra: missing protocol parameter
Apr 20, 2020 00:11:08.416 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Apr 20, 2020 00:11:08.416 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Apr 20, 2020 00:11:08.416 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Apr 20, 2020 00:11:08.416 [0x7f7300ff9700] WARN - ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Apr 20, 2020 00:11:08.416 [0x7f7300ff9700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Apr 20, 2020 00:11:43.810 [0x7f73247f4700] WARN - Got a transcode session ping without a session GUID (or with an invalid one).
