Issues with Plex Arcade in iOS device
I’m having problems using Plex Arcade with my iOS device.
I setup Plex Arcade correctly, linked my Parsec account and I created the standard Atari library.
I can open the library from my Phone (iPhone 11 Pro) and I can execute a game. If I close the game and try to open other game, it does not play and the screen stays in the loading state…
After that, no game works until I restart Plex Game Transcoder.exe :frowning:
After restarting the process, I can play a game again… but after that, same problem.
And I am also having problems with the on screen controls. D-pad does not work from my device. When I press the buttons, the phone bibrates, but the action does not work. A, B, select, start buttons works. My phone is iPhone 11 Pro with latest iOS updates and the latest Plex update.
Thanks in advance for your help.
After 3-4 app restarts, D-Pad is working :slight_smile:
But I’m still experiencing the other problem.
No special configurations or cores. Just trying with the Atari library.
I am having this issue too. I see on my windows PC that when I go back to the Plex menu in the iPhone native app the “Plex Game Transcoder.exe” does not close… and this stops any other game from loading.
If you go into the server and end task on the Plex Game Transcoder… the iPhone native app can launch the next game.
I know this feature is new… I am happy to test any beta version to resolve these issues :slight_smile:
I’m having the same issue. Every time I want to start a new game on the ios , I need to kill the Plex Game Transcoder. Just note while playing on Chrome. I can switch game and no issue.
Thanks,
I had to do the same thing as you guys, but for me the mappings are off… the NES A/B are Y/B on the touchscreen/controller
I am still having this issue on Iphone. Has anyone found a solution or it still in the works.
