Server Version#:1.20.4.3517-ab5e1197c
Player Version#:1.23.0.1435-e10e14cf
Hello, I’m having issues with my Plex Media Server. I keep getting “EAE timeout! EAE not running, or wrong folder? Could not read” Errors when people are attempting to playback media. If i restart the server it seems to fix the issue for a while (a few hours to days). However, it eventually comes back and starts having issues again. I have tried:-
creating a new Tmp folder and directing plex there
Making sure Plex has full control and ownership of all folders and files in the plex directory
Rolling back the plex version
Making sure plex is the latest version
deleting the codecs folder
uninstalling plex and reinstalling
I don’t think it’s an issue I have read about with “the number of folders limit” if that were the case why would it work when I reboot the server for a while?
I have had the server for around 4/5 years and never had this issue until the last month, if anyone could help me i would be really happy as its beyond my ability to fix now.
Yes, after I restarted the server I became able to play the media file, however, before the restart I was unable to.
Ok, so i need to figure out the amount of media folders on the entire system or just within plex itself?
Yes, this is just a disconnected USB drive from the Synology unit.
I did manage to find this information in another threat and did action these instructions.
However, it has not seemed to fix the issue with the correct EAE
Plex is saved to volume 1 on my system and my media is saved to volume 2
All the file and folder info i can find is below, with as much detail as i can give.
The total number of folders plex is watching :-
Video folder (Volume 2)
Folders : 10414
Files including metadata & jpeg etc : 174746
Plex Folder (Volume 1)
Folders : 756141
Files including plex’s metadata & images : 799306
Music Folder (Volume 2)
Folders :1341
Files : 12475
There are other folders on the system, however plex is not pointed at them currently. Do i need the file and folder information from them also?
Well, this is about the maxium level of my ability now.
From reading the article i understand it as this:
First, get the total number of directories in use for your media (movies, series, music, and photos). For each share containing media:
a. File Station.
b. Left Pane
c. Right-click the share
d. Properties
e. Write down the number of folders it finds.
Video folders = 10414, Music Folders = 1341 Total = 11,755
Ignore the plex folder
a. Add 32768 to the value = 44,523
b. Divide by 32768 = 1.358734130859375 (1.35)
c. Add 1 to the the Integer result (No fractions here) = 2.35
e. Multiply by 32768 = 77004.8
f. Use this final result. (integer part only) = 77004.8 or 77004?
g. If the number of folders you are using is less than 8192, stop here unless you are about to add a lot more media. = The number is higher.
Create a Scheduled task you will run ONE TIME -OR- when DSM updates and you need to increase the table again. = I need to do this as my number is higher?
Remove any previous s2s_watches_max entries (avoid clutter)
sed -i ‘s/^s2s_watches_max=.*//' /etc/synoinfo.conf
sed -i 's/^s2s_watches_max=.*//’ /etc.defaults/synoinfo.conf
This is an example only. Use your actual result below to add the new value
Hello, I have now done this however i didn’t apply the
now discard the fractional part → 0 0 + 1 = 1
So used the number 77004, will this have a negative effect? i have restarted the system after running the command and the red text in console about not enough inotify space has stopped on boot up and now reports that notify is now watching the folders that had been showing up as red due to not enough space.
I can’t take a screen shot as it seems to be fixed and working now but i was seeing red messages in the console on start up that refered to notify. Something along the lines of “notify unable to watch folder due to insufficient space. (then the name of a folder)” But after applying the :
I restarted the entire Synology unit and then waited 2mins then downloaded logs.
Do I need to run the script via the Task Scheduler on every system restart?
Can i just restart the Package and wait 2mins or do i need to restart the whole Nas drive again?
It’s strange as i restarted the Nas completely then let the PMS package restart then waited then downloaded the logs
