Issues with transcoder after latest update
Server Version#: 1.32.8.7639
Player Version#: NA
I have a Synology DS220+ with the latest update of Plex Media server. The transcoder was working perfectly fine before the update and now, every time I have it do media optimization for a movie or do the on demand transcoding for a client, my CPU spikes to between 50 to 75% instantaneously and the transcoder just hangs. Stays at -1%. Before, the server would transcode movies just fine it would take maybe anywhere between 1 hour and two depending on the movie and what it’s transcoding and it could transcode multiple streams at a time, all with the CPU staying below 5%. It appears to me that after this update the GPU is not being utilized at all and instead plex media server is trying to use the CPU to transcode, which is not ending very well. I’m currently working right now but I’d be happy to send server logs when I get home. I’m planning on rolling back the update until this can get fixed.
Can you please recreate and capture this for me (DEBUG logging enabled – which is the default) then download the server logs ZIP file?
From that ZIP file, I’ll be able to see the start of playback and why it’s doing what it’s doing.
Based on your description , and the DS220+ being a dual core CPU, I suspect subtitles are getting involved / interfering.
Plex Media Server Logs_2023-12-05_16-14-22.zip (4.5 MB)
The title I’m trying to optimize is one of the Lord of the Rings movies, it just hangs at -1%. Other on the fly encoding seems to work okay, but it appears to be utilizing the CPU instead of the GPU for encoding.
Listing a few things I see:
  1. Two adapters on the same network – Not good TCP/IP practice.
Dec 04, 2023 19:26:03.125 [140245365275280] DEBUG - Network interfaces:
Dec 04, 2023 19:26:03.125 [140245365275280] DEBUG -  * 1 lo (127.0.0.1) (00-00-00-00-00-00) (loopback: 1)
Dec 04, 2023 19:26:03.125 [140245365275280] DEBUG -  * 3 eth0 (10.119.40.7) (00-11-32-D6-6E-F5) (loopback: 0)
Dec 04, 2023 19:26:03.125 [140245365275280] DEBUG -  * 4 eth1 (10.119.40.9) (00-11-32-D6-6E-F6) (loopback: 0)
Dec 04, 2023 19:26:03.125 [140245365275280] DEBUG -  * 1 lo (::1) (00-00-00-00-00-00) (loopback: 1)
Dec 04, 2023 19:26:03.125 [140245365275280] DEBUG - Creating NetworkServices singleton.
– If you want both, create bond0. One IP, no confusion with Remote Access, aggregated throughput.
  1. Your logs show me Playback starting before PMS finished starting up. Better would be to give it a minute before starting playback of music or video.
  2. You’re pushing it hard. That’s a lot of bitrate for a NAS dual core CPU.
Dec 04, 2023 19:49:23.181 [140245288532792] DEBUG - [Req#c09/Transcode] [FFMPEG] - Decode to surface 0x4000013.
Dec 04, 2023 19:49:23.181 [140245288532792] DEBUG - [Req#c09/Transcode] Codecs: dummy-frame test succeeded
Dec 04, 2023 19:49:23.182 [140245288532792] DEBUG - [Req#c09/Transcode] MDE: Cannot direct stream audio stream due to codec truehd when profile only allows aac
Dec 04, 2023 19:49:23.182 [140245288532792] DEBUG - [Req#c09/Transcode] MDE: Jellyfish 140 Mbps 4k: selected media 0 / 22349
Dec 04, 2023 19:49:23.183 [140245288532792] DEBUG - [Req#c09/Transcode] Streaming Resource: Adding session 0x7f8d671b0c68:9dp17z174xphut45x6t6desv which is using transcoder slot.  Used slots is now 1
  1. I see your Lord of the Rings playback attempt. I also see the transcoder failure.
  2. Are you also trying to playback music concurrent with this?
The biggest problem I see here is the host getting slammed
Are you trying to Optimize the JellyFish 140 Mbps just as a test or do you want it for other purpose ??
The version you have also has TrueHD in it. I don’t have that in my files from the original site.
Dec 04, 2023 19:50:12.431 [140245256891192] DEBUG - [Req#f39/Transcode] MDE: Cannot direct stream audio stream due to codec truehd when profile only allows aac
Dec 04, 2023 19:50:12.431 [140245256891192] DEBUG - [Req#f39/Transcode] MDE: Jellyfish 140 Mbps 4k: selected media 0 / 22349
Regarding your Lord of the Rings file, You have WAY TOO MANY subtitles in it.
You need to clean it out.
Dec 05, 2023 16:14:14.867 [140245244169016] DEBUG - [Req#8361] BPQ: generator 1143 changed state: pending -> complete
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: Selected protocol http; container: mp4
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: analyzing media item 20186
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): multi-part media requires a transcode when all parts are selected
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no direct play video profile exists for http/mkv/mpeg2video
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no direct play video profile exists for http/mkv/mpeg2video/ac3
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31861 cannot be direct-played
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31862 cannot be direct-played
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31863 cannot be direct-played
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31864 cannot be direct-played
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31865 cannot be direct-played
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31866 cannot be direct-played
Dec 05, 2023 16:14:14.871 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31867 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no direct play video profile exists for http/mkv/mpeg2video/dca
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31861 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31862 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31863 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31864 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31865 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31866 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31867 cannot be direct-played
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no direct play video profile exists for http/mkv/mpeg2video/ac3
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): avoiding video remux due to part concatenation
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no remuxable profile found, so video stream will be transcoded
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: Cannot direct stream video stream due to profile or setting limitations
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): We're concatenating parts, so video's audio stream will be transcoded
Dec 05, 2023 16:14:14.872 [140245305465656] DEBUG - [Req#8100] MDE: Cannot direct stream audio stream due to profile or setting limitations
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: Cannot direct stream audio stream due to profile or setting limitations
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): We're concatenating parts, so video's audio stream will be transcoded
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): multi-part media requires a transcode when all parts are selected
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no direct play video profile exists for http/mkv/mpeg2video
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no direct play video profile exists for http/mkv/mpeg2video/ac3
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31924 cannot be direct-played
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31925 cannot be direct-played
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31926 cannot be direct-played
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31927 cannot be direct-played
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31928 cannot be direct-played
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31929 cannot be direct-played
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): non-selected embedded subtitle stream 31930 cannot be direct-played
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no direct play video profile exists for http/mkv/mpeg2video/dca
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): avoiding video remux due to part concatenation
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): no remuxable profile found, so video stream will be transcoded
Dec 05, 2023 16:14:14.873 [140245305465656] DEBUG - [Req#8100] MDE: Cannot direct stream video stream due to profile or setting limitations
Dec 05, 2023 16:14:14.874 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): We're concatenating parts, so video's audio stream will be transcoded
Dec 05, 2023 16:14:14.874 [140245305465656] DEBUG - [Req#8100] MDE: Cannot direct stream audio stream due to profile or setting limitations
Dec 05, 2023 16:14:14.874 [140245305465656] DEBUG - [Req#8100] MDE: The Lord of the Rings: The Return of the King (2003): selected media 0 / 20186
The JellyFish was a benchmark. I was intentionally pushing the transcoder. that would make sense about the Lord of the Rings file, which is my primary concern here. But it doesn’t answer why it’s utilizing the CPU, I thought it utilized just the GPU decoder/encoder (or am I wrong here?). Also, I have the optimizer set to “very slow”, could that have a part in it?
@HurdBlessings
When you have subtitles in the file (specifically PGS, VOBSUB, or DVDRIP – image based), the transcoder forcibly engages
This happens because only physical BR disk players can overlay images in real-time playback.
At this point (which we’re working on changing), Subtitle ‘burning’ (overlaying) is done by the CPU.
If you turn off / disable subtitles and play – all should be fine and transcode easily.
When you enable subtitles, PMS must switch to Software Encoding . This is where the CPU load comes from.
Hardware is performed by the embedded QSV module but Software is just raw ‘crunch’ power. Synology NAS CPUs (and unfortunately especially any dual core) suffers badly.
