Issues with ver 1.69.1.3755-e00242c8 on MacOS
Server Version#: 1.32.2.7100
Player Version#:1.69.1.3755-e00242c8
The player on MacOS will not exit when doing Command Q. It hangs. You have to do a force quit to fully stop the app. This is on MacOS Running Ventura 13.4 on M1 Pro.
I did not know where exactly to log the bug.
I have the same issue
Same here, I need to force quit every time to close the app.
Yes, me too. Works fine until I try to quit. Then hangs and must be force-quit.
Same. It is happening since the latest player’s update.
Known problem. Mentioned in another thread it will be fixed in the 1.70 release.
same here, plus it’s not processing clicks when using a Wacom Tablet to push buttons.
Can you post a URL to the thread?
I’m having the same issue here. Having to force quit when closing.
I mean this sincerely, but what does this say about a deployment process when - we can deduce - not a single person working for Plex attempted to run/quit the MacOS Plex release. This is second only to a release not even opening, and it remaining as a download for days.
I have the same issue.
Yep same issue for me, glad it has been fixed in the future 1.70.x release.
