Server Version#: 1.29.0.6244
I have 3 servers running this version of Plex, all on MacOS laptops. The server which is not importing my playlist is an older version of macOS with an Intel chip. The other 2 are running on M1. While it has been successfully importing iTunes playlists for years, it no longer imports them from my Library.xml file. It doesn’t error out. It runs for about 10 seconds, and the playlists do not appear at all. I’ve looked at every setting in Plex for comparison with one of the other identical servers.
the Intel server is also, just in the last few days, indicated that its status is “Indirect” and not “Nearby” like my other 2 servers. It can’t seem to get it recognized by the other 2 servers on the same network.
Does that have something to do with it not importing the playlists successfully?
