Server Version#: 1.25.1.5286-34f965be8
Player Version#: 8.25.1.28703
OS: Windows 10
iTunes Version#: 12.12.2.2
When I add a music library, I can not get playlists imported from iTunes anymore. It used to work, but after I lost my C drive, I had to set up everything from scratch again (server, libraries, switch from Windows 8 to 10). I made sure to:
- check mark “share iTunes Library XML with other applications” in iTunes
- check mark “Import from iTunes” in the Advanced settings when adding the library
- check mark “enable iTunes Plugin” in the Server Plugins setting (and restarted Plex server).
- specify the iTunes Library XML path: C:\Users[my username]\Music\iTunes\iTunes Music Library.xml
What am I missing??
