Server Version#: 1.19.5.3112
Player Version#: PMP 4.29.2 (old), PMP 2.58 (latest) and Plex for windows 1.16.0.1364
Plex Media Server Logs_2020-08-05_02-56-46.zip (4.6 MB)
fresh windows 10 install on a minisforum S40 computer-on-a-stick. Intel UHD 600 graphics. Output is a 65inch samsung 4k TV. Server is on windows 10, remote
Same problem occurs using Plex for windows and PMP: judder when running either desktop app in full screen on a 4k television.
When running windowed (i,e, not full screen), judder does not occur.
When running web player, judder does not occur, even in full screen. (edit: judder now occurs in plex web app)
I am always running original quality, file is only 2.7 mbps bitrate. Tried a lower bitrate file and same results.
Tried suggestions from another thread:
- read only plex.ini, didn’t work
- setting useOpenGL and useSystemVideoCodecs to true in plexmediaplayer.conf, didn’t work
Installed the intel graphics driver and software, instead of the microsoft driver, didn’t help.
Tried 60p and 30p output, problem still occurs.
I thought it might be some sort of refresh rate switching problem, but I can’t find any setting for that in the intel display adapter software
Tried the minisforum computer on a different TV, problem still occurs
Meanwhile, a separate older computer-on-a-stick (intel compute stick) works fine on both TVs running PMP, even though it has weaker CPU and GPU
