Jujutsu Kaisen Specials Folder doesn't appear
Server Version#: 1.29.2.6364
Player Version#: 4.87.2
Hello, as the title says my Specials folder for JK is not showing up. I believe I have it set up correctly;
Jujutsu Kaisen/Specials/Jutsu Kaisen (2020) - S00E02 - 025 - Jujutsu Kaisen 0.mkv
Any help would be greatly appreciated.
When in doubt, perform the Plex Dance.
Thank you for the response, so I understand this Plex Dance correctly, I need to move my files from my Anime directory, rescan, I’m not sure where the trash is though, clean the bundles then add the files back into the Anime directory?
It looks like TMDB only lists that episode as a movie
Click the pencil in the show poster –> Advanced
Make sure you’re using the TVDB show order
Save changes and refresh metadata
As a side note i’m not sure what “025” designates in the episode name but i’m not sure it’s needed. I tried it just as …
Jujutsu Kaisen (2020)/Season 00/Jujutsu Kaisen.S00E02.Jujutsu Kaisen 0.mp4
Screenshot (820)
Thanks, brother I appreciate the help, I just did the edits as you mentioned, and refreshed the meta-data and it just won’t change.
I tried this solution as well, and it didn’t work for me, but thanks for the help.
Perhaps the typo is at fault here.
So I was further investigating that - 025, and it turns out that TheTVDB uses that as it’s an absolute number. So, I’m guessing they are saying this comes after episode 024. I’ve tried to delete the absolute number refreshed and rescanned and nothing, it won’t show up.
