Right now I had it set up and I didn’t care for it with the single USB tuner from Hauppauge I took it from my Xbox so I bought the HD connect Quatro and if I understand correctly I will be able to record four channels at the same time with Plex? And if I’m only recording two channels I can use the HD app and watch two other channels on other TVs am I getting this all correct?
Thank you
Probably not. Plex assumes it has access to all four tuners; it doesn’t share very well.
Okay so if I’m recording two Channels with Plex I would be able to watch two other channels on Plex live?
Also with the hdhomerun will Plex support Quatro and then also support the hdhomerun CableCARD unit? I’m probably going to end up posting that as a second thread but I figured I’d ask while I was asking
If you use a quatro in a Duo can you support six tuners and if used to quatro’s can you support a tuners?
