Erste Problem gefunden: Datenbank optimieren um die Verschlechterung zu korrigieren
Apr 16, 2018 17:06:31.488 [0x7f0347111700] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 21.880841 seconds: 192.168.178.30
Apr 16, 2018 17:06:44.544 [0x7f034ebff700] WARN - SLOW QUERY: It took 590.000000 ms to retrieve 0 items.
Apr 16, 2018 17:07:01.488 [0x7f0347111700] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 29.781852 seconds: 192.168.178.35
Nach Datenbank optimieren, bitte Plex neustarten.
wie kann ich die Datenbank optimieren, wenn ich auf den Server keinen Zugriff mehr per web oberfläche habe?
/ how can i optimize the database if i can’t access the server via web anymore…
Sorry, could you provide me with instructions on how this has to be done on synology nas servers?
So i used SSH:
i am not sure on whether the Commands are line by line or if it is a code tha has to be entered at once.
However when trying:
“cat “/home/plexdir/Library/Application Support/Plex Media Server/Preferences.xml” |
sed -e 's;^.* PlexOnlineToken=”;;’ | sed -e ‘s;".*$;;’ | tail -1 > /tmp/plex.tmp"
the server responds: "cat: /home/plexdir/Library/Application Support/Plex Media Server/Preferences.xml: No such file or directory "
do i have to edit the path? Both for/home/plexdir and the curl request?
so i don’t know why, but now when using the
sudo -su root
it tells me that my password is wrong… I am feeling a little stupid now, but it should be the normal admin password?
i am not really sure what you mean by your previous post, but i have been using ssh programs to sign on.
The first one had problems with my password
now i am using putty: Syntax error occured near unexpected token `;;’
after checking the logs where it stated that the database has been optimized, i stopped and restarted the plex package…
unfortunately it still says searching for servers…
Do you need new log files?
To me it seems pretty weird that the server is doing all that debugging:
DEBUG - [Notify] Now watching…
as well as ERROR - [Notify] Failed to add watch for xyz (28: No space left on device)
