Keep left side bar from resetting to top?
Is there a way to keep the left side bar from jumping all the way back up to the top on every page load?
After selecting a library and then choosing an item from the main area of the screen, then pushing back, the main area of the screen stays where it was scrolled to, but the left side menu never does.
What am I missing?
Server Version#: 1.18.3.2129
Player Version#: Plex Web 4.16.3
Are your libraries pinned?
I have a small sample of libraries pinned. I should have specified that it occurs when I click on “more” to show the list of all libraries across all servers.
Yes, that’s unfortunately a known weakness of the used javascript framework(s) with which the web app is built.
The Pinned section is Alphabetically arranged as opposed to the working Library customization. I would gather each server would be the same. I only use my own Library that I share.
So are you saying that this isn’t going to get fixed?
I brought this up when we were beta testing UNO…
It might eventually get fixed, but not shortly.
