Has anyone else had any issues with having several Xbox One's/360's on your account and it asking for a pin on them almost every time you try and use it?
Are you trying to use the same plex.tv account with multiple xbox live accounts? This is the only way I've heard of this happening. The linking between the accounts is 1 to 1.
Yes, hm. Guess that makes sense. So I keep kicking out the other Xbox when I sign in with one. Any word when they will release the one time payment version so I can have it on both with different Xbox live accounts?
Thanks for the answer adamskoog, I looked for documentation talking about association with accounts.
Exactly.
You can right now if you have Plex Home setup. You make a plex.tv user for the other person and add them to your Home, then they can piggy back on your Plex Pass and sign into the app. I think this only works on the Xbox One at the moment though, haven't see anything in the release notes about them having added this to the 360.
Plex hasn't said when the Plex Pass period will be over, and better or worse they never release timelines. So we likely won't know until the day it happens.
Exactly.
Figured out the workaround. Thanks!
