Server Version#: 1.18.3.2111
Player Version#: any
Hi there,
I’m running Plex Media Server on my HP MicroServer Gen 8 with 16GB of RAM.
It’s running Fedora 31 (x86_64) and I’ve installed a GeForce GTX 1050Ti for HW transcoding.
My nVidia Driver version: 440.36
I’m also using the nvidia-patch for enabling more than two sessions.
Furthermore I’m blacklisting nouveau and enabling modesetting (in kernel cmd):
rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1
I’ve renamed: “/usr/lib/plexmediaserver/Plex Transcoder”
To: “/usr/lib/plexmediaserver/Plex Transcoder2”
Then I’ve created a new “/usr/lib/plexmediaserver/Plex Transcoder” executable file that says:
#!/bin/sh
exec /usr/lib/plexmediaserver/Plex\ Transcoder2 -hwaccel nvdec "$@"
Now it seems to be working according to the output of nvidia-smi:
| NVIDIA-SMI 440.36 Driver Version: 440.36 CUDA Version: 10.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GTX 105... Off | 00000000:07:00.0 Off | N/A |
| 0% 47C P0 N/A / 75W | 286MiB / 4039MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 193760 C /usr/lib/plexmediaserver/Plex Transcoder2 273MiB |
But it sometimes seems to give a kernel crash every now and then:
[40809.424195] Plex Media Serv: page allocation failure: order:0, mode:0x10dc0(GFP_KERNEL|__GFP_NORETRY|__GFP_ZERO), nodemask=(null),cpuset=/,mems_allowed=0
[40809.424200] CPU: 6 PID: 6506 Comm: Plex Media Serv Tainted: P OE 5.3.13-300.fc31.x86_64 #1
[40809.424201] Hardware name: HP ProLiant MicroServer Gen8, BIOS J06 04/04/2019
[40809.424202] Call Trace:
[40809.424210] dump_stack+0x66/0x90
[40809.424212] warn_alloc.cold+0x7b/0xfb
[40809.424216] __alloc_pages_slowpath+0xdc4/0xe00
[40809.424219] __alloc_pages_nodemask+0x2ee/0x340
[40809.424238] uvm_mem_alloc+0x245/0x3b0 [nvidia_uvm]
[40809.424251] uvm_va_range_create_semaphore_pool+0x176/0x290 [nvidia_uvm]
[40809.424262] uvm_api_alloc_semaphore_pool+0xf6/0x1a0 [nvidia_uvm]
[40809.424270] uvm_ioctl+0xedc/0x1360 [nvidia_uvm]
[40809.424473] ? _nv008350rm+0x1d/0x30 [nvidia]
[40809.424475] ? ns_capable_common+0x2e/0x50
[40809.424642] ? _nv008375rm+0x60/0x80 [nvidia]
[40809.424739] ? os_is_administrator+0xf/0x20 [nvidia]
[40809.424906] ? _nv007504rm+0xd0/0x130 [nvidia]
[40809.425025] ? os_acquire_spinlock+0xe/0x20 [nvidia]
[40809.425263] ? _nv033270rm+0xc/0x20 [nvidia]
[40809.425423] ? _nv036742rm+0xac/0x170 [nvidia]
[40809.425426] ? update_load_avg+0x76/0x600
[40809.425457] uvm_unlocked_ioctl+0x31/0x60 [nvidia_uvm]
[40809.425471] uvm_unlocked_ioctl_entry+0x89/0xb0 [nvidia_uvm]
[40809.425475] do_vfs_ioctl+0x405/0x660
[40809.425478] ksys_ioctl+0x5e/0x90
[40809.425480] __x64_sys_ioctl+0x16/0x20
[40809.425484] do_syscall_64+0x5f/0x1a0
[40809.425488] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[40809.425490] RIP: 0033:0x7ff93ebb234b
[40809.425493] Code: 0f 1e fa 48 8b 05 3d 9b 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 0f 1f 44 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 0d 9b 0c 00 f7 d8 64 89 01 48
[40809.425494] RSP: 002b:00007ff8857f4ee8 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[40809.425496] RAX: ffffffffffffffda RBX: 00007ff87c538f90 RCX: 00007ff93ebb234b
[40809.425497] RDX: 00007ff8857f5270 RSI: 0000000000000044 RDI: 0000000000000060
[40809.425497] RBP: 00007ff8857f5270 R08: 0000000000000001 R09: 00007ff8857f5270
[40809.425498] R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000044
[40809.425499] R13: 0000000000000060 R14: 0000000205c00000 R15: 0000000000000000
[40809.425528] Mem-Info:
[40809.425535] active_anon:574979 inactive_anon:15075 isolated_anon:0
active_file:1138313 inactive_file:1910555 isolated_file:0
unevictable:0 dirty:9976 writeback:0 unstable:0
slab_reclaimable:61051 slab_unreclaimable:64858
mapped:243376 shmem:15263 pagetables:4412 bounce:0
free:49018 free_pcp:1 free_cma:0
[40809.425539] Node 0 active_anon:2299916kB inactive_anon:60300kB active_file:4553252kB inactive_file:7642220kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:973504kB dirty:39904kB writeback:0kB shmem:61052kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 120832kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[40809.425540] Node 0 DMA free:15884kB min:64kB low:80kB high:96kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15968kB managed:15884kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[40809.425544] lowmem_reserve[]: 0 3313 15915 15915 15915
[40809.425546] Node 0 DMA32 free:64132kB min:14056kB low:17568kB high:21080kB active_anon:247824kB inactive_anon:0kB active_file:1050624kB inactive_file:1918972kB unevictable:0kB writepending:13064kB present:3487632kB managed:3422096kB mlocked:0kB kernel_stack:544kB pagetables:716kB bounce:0kB free_pcp:8kB local_pcp:0kB free_cma:0kB
[40809.425549] lowmem_reserve[]: 0 0 12601 12601 12601
[40809.425551] Node 0 Normal free:116056kB min:116948kB low:130312kB high:143676kB active_anon:2052092kB inactive_anon:60300kB active_file:3502692kB inactive_file:5723636kB unevictable:0kB writepending:26840kB present:13238268kB managed:12912116kB mlocked:0kB kernel_stack:10032kB pagetables:16932kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[40809.425555] lowmem_reserve[]: 0 0 0 0 0
[40809.425557] Node 0 DMA: 1*4kB (U) 1*8kB (U) 0*16kB 0*32kB 2*64kB (U) 1*128kB (U) 1*256kB (U) 0*512kB 1*1024kB (U) 1*2048kB (M) 3*4096kB (M) = 15884kB
[40809.425567] Node 0 DMA32: 69*4kB (UM) 114*8kB (UME) 74*16kB (UME) 61*32kB (ME) 68*64kB (UME) 30*128kB (ME) 17*256kB (UM) 8*512kB (UME) 11*1024kB (UME) 12*2048kB (UM) 2*4096kB (UM) = 64996kB
[40809.425576] Node 0 Normal: 1123*4kB (UMEH) 885*8kB (UMEH) 454*16kB (UMEH) 920*32kB (UME) 884*64kB (UME) 97*128kB (UME) 1*256kB (M) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 117524kB
[40809.425585] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[40809.425585] 3062277 total pagecache pages
[40809.425587] 0 pages in swap cache
[40809.425588] Swap cache stats: add 0, delete 0, find 0/0
[40809.425588] Free swap = 0kB
[40809.425589] Total swap = 0kB
[40809.425589] 4185467 pages RAM
[40809.425590] 0 pages HighMem/MovableOnly
[40809.425590] 97943 pages reserved
[40809.425591] 0 pages cma reserved
[40809.425591] 0 pages hwpoisoned
[40809.794447] Plex Media Serv: page allocation failure: order:0, mode:0x10dc0(GFP_KERNEL|__GFP_NORETRY|__GFP_ZERO), nodemask=(null),cpuset=/,mems_allowed=0
[40809.794452] CPU: 6 PID: 6506 Comm: Plex Media Serv Tainted: P OE 5.3.13-300.fc31.x86_64 #1
[40809.794453] Hardware name: HP ProLiant MicroServer Gen8, BIOS J06 04/04/2019
[40809.794453] Call Trace:
[40809.794461] dump_stack+0x66/0x90
[40809.794464] warn_alloc.cold+0x7b/0xfb
[40809.794468] __alloc_pages_slowpath+0xdc4/0xe00
[40809.794471] __alloc_pages_nodemask+0x2ee/0x340
[40809.794492] uvm_mem_alloc+0x245/0x3b0 [nvidia_uvm]
[40809.794504] uvm_va_range_create_semaphore_pool+0x176/0x290 [nvidia_uvm]
[40809.794515] uvm_api_alloc_semaphore_pool+0xf6/0x1a0 [nvidia_uvm]
[40809.794524] uvm_ioctl+0xedc/0x1360 [nvidia_uvm]
[40809.794733] ? _nv008350rm+0x1d/0x30 [nvidia]
[40809.794737] ? ns_capable_common+0x2e/0x50
[40809.794907] ? _nv008375rm+0x60/0x80 [nvidia]
[40809.795005] ? os_is_administrator+0xf/0x20 [nvidia]
[40809.795173] ? _nv007504rm+0xd0/0x130 [nvidia]
[40809.795270] ? os_acquire_spinlock+0xe/0x20 [nvidia]
[40809.795440] ? _nv033270rm+0xc/0x20 [nvidia]
[40809.795539] ? _nv036742rm+0xac/0x170 [nvidia]
[40809.795541] ? update_load_avg+0x76/0x600
[40809.795552] uvm_unlocked_ioctl+0x31/0x60 [nvidia_uvm]
[40809.795560] uvm_unlocked_ioctl_entry+0x89/0xb0 [nvidia_uvm]
[40809.795563] do_vfs_ioctl+0x405/0x660
[40809.795564] ksys_ioctl+0x5e/0x90
[40809.795565] __x64_sys_ioctl+0x16/0x20
[40809.795567] do_syscall_64+0x5f/0x1a0
[40809.795569] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[40809.795571] RIP: 0033:0x7ff93ebb234b
[40809.795574] Code: 0f 1e fa 48 8b 05 3d 9b 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 0f 1f 44 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 0d 9b 0c 00 f7 d8 64 89 01 48
[40809.795575] RSP: 002b:00007ff8857f51a8 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[40809.795576] RAX: ffffffffffffffda RBX: 00007ff87c306670 RCX: 00007ff93ebb234b
[40809.795577] RDX: 00007ff8857f5530 RSI: 0000000000000044 RDI: 0000000000000060
[40809.795578] RBP: 00007ff8857f5530 R08: 0000000000000001 R09: 00007ff8857f5530
[40809.795578] R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000044
[40809.795579] R13: 0000000000000060 R14: 0000000205c00000 R15: 0000000000000000
Any ideas?
Does it run out of memory? or is my RAM bad/damaged?
Any ideas would be helpful.
Thanks in advance!
