Server Version#: 1.15.4.993
Player Version#: 3.95.2
Hi everyone,
a recent version of the client provides the ability to change the subtitles offset, that is great.
However, I would find it more convenient if we had some keyboard shortcut to trigger the ±50ms without having to open the option menu for that.
For exemple, MPV uses z/x for that, however x is already used by the web client.
I think a one-key shortcut (not like g then s for exemple) is preferable as it will need to be triggered multiple times to adjust the offset.
