Plex REALLY needs to allow users to have choice in the way they use Plex to play their media.
I will use the implementation of the “Post Play” screen as an example. Plex decided, possibly based on user input, that a “special” screen was needed that shows up after media plays to allow selection of the next item to play. They decided that Plex was better at choosing what to do next than the user themselves are.
In doing this Plex now interposes a screen after an item plays where a very few choices are presented and it takes a press of the back button or some such equivalent to get back to where the video was started. That is if you play a movie directly from browsing you have to press back to get back to browsing after the movie completes and, at least in my case, the Post Play screen always presents choices for movies that are worse than a simple random choice would be. ex. I played a “Harry Potter” movie for my granddaughters and the post play screen suggested “Dirty Harry,” “Dog Day Afternoon” and “Star Wars” among others and not even one of the other "Harry Potter movies. This is simply horrible programming or simple incompetence.
I will say that for TV shows the Post Play screen works well and I like it but for movies it is quite intrusive and make Plex a bit unpleasant to use.
Plex should allow enabling/disabling Post Play on a per-library basis and the same goes for the auto-play sub-function of Post Play. That is I should be able to say I want to have Post Play without auto-play on my TV shows and Post Play with auto-play on my cartoons and absolutely no Post Play on my movies. If Plex cannot do it on a per-library basis then they should at least allow the full Post Play screen to be turned on or off.
If Plex implemented Post Play without thinking that people might not like it then they screwed up and showed again that they care little for their users forcing everyone to use Plex exactly the same way. That is Plex is trying to make every Plex setup exactly the same making Plex an electronic equivalent of “Trac” houses:
Little boxes on the hillside,
Little boxes made of ticky tacky,
Little boxes all the same.
There’s a green one and a pink one
And a blue one and a yellow one,
And they’re all made out of ticky tacky
And they all look just the same.The first verse of “Little Boxes” by Malvina Reynolds
That is what Plex seems to want our media libraries to be. Different content on the inside but accessed and displayed and used exactly the same.
Plex should embrace diversity and when a new feature gets added that might be disliked by some allow the users as choice as possible in the use and implementation of that feature.
There are many other examples where Plex has decided that users are unable to exercise choice intelligently and therefore Plex should choose for the poor users but this one is simply the most recent example of Plex playing media God.
