I just had a long conversation with TMDB support about this, and according to them, you should check for the presence of a LOGO in FR-FR, and if not, display the original LOGO.
For example, the film “Highest 2 Lowest” currently displays the Quebec LOGO “Du ciel à l’enfer” instead of keeping the original title…
Is it possible to fix this major bug, which creates significant inconsistencies in the presentation of the listings for many films and TV series?
Thank you for your feedback,
Vincent
