Plex Media Server [0]:
1.13.8.5395-10d48da0d
[Plex Media Server]
[PC]
[FreeBSD 11.2-STABLE (FreeBSD 11.2-STABLE #0 r325575+97f4f541349(freenas/11.2-stable): Wed Oct 17 18:06:49 EDT 2018 root@nemesis.tn.ixsystems.com:/freenas-11.2-releng/freenas/_BE/objs/freenas-11.2-releng/freenas/_BE/os/sys/FreeNAS.amd64)]
Plex Media Player [1] [ Local-Network (WiFi) ]:
5.3.10.5048-c61db7547-Plex
[Plex for Roku]
[Roku 3]
Plex Media Player [2] [ Local-Network (WiFi) ]:
3.67.1
[Plex Web]
[OSX]
Issue:
Some files play, large files hang at 33% during loading bef> ore failing to play.
Occurs on Roku 3 and laptop web app.
Attempted Resolution:
Recommendations have been to manually set the transcoder temporary directory:
Plex > Settings > Server > Transcoder > Transcoder temporary directory
• What is the default transcoder temporary directory for freeNAS?.
• What should I change the default transcoder directory to?
(I’m going to be very specific with examples because
I’m not really sure where I should and should not create things.)
• Should I choose an already existing directory within the jail:
Examples
[Plex: Settings: Server: Transcoder: Temporary Directory]:
/tmp
/dev
/usr
• Should I create and choose a directory which is
within an already existing directory within the jail?
Examples
/tmp/transcodez
/dev/transcodez
/usr/transcodez
[Someone said: Try /dev/shm.]
[Didn’t work.]
• Should I create a dataset within the jail and then
choose that dataset (or create and choose a directory within it)?
Examples
[FreeNAS: Create dataset]:
/mnt/poolName/iocage/jails/plex/temp
/mnt/poolName/iocage/jails/plex/root/temp
../temp/transcodez
/temp/transcodez
• Should I create a dataset external to the jail, mount it to the jail, and then
choose that mount directory (or create and choose a directory within it)?
Examples
/mnt/poolName/temp
[FreeNAS: Jails: Plex:: Mount: Source]:
/mnt/poolName/temp
[FreeNAS: Jails: Plex:: Mount: Destination]:
/mnt/poolName/iocage/jails/plex/root/dev/transcodez (?)
/mnt/poolName/iocage/jails/plex/root/dev/shm/transcodez (?)
/mnt/poolName/iocage/jails/plex/root/tmp/transcodez (?)
/mnt/poolName/iocage/jails/plex/root/usr/transcodez (?)
/dev/transcodez (?)
/tmp/transcodez (?)
/usr/transcodez (?)
[Someone said: Try this:]
/mnt/poolName/temp/plex
[FreeNAS: Create directory]:
/mnt/poolName/temp/plex/transcodes
/mnt/poolName/iocage/jails/plex/root/mnt/temp/transcodes
[Didn’t work.]
Alternative considerations possibly contributing to the issue:
Choose a dataset or directory without size restrictions.
Does the default transcoder temporary directory have size restrictions?
Do all or certain directories within the plex jail have size restrictions?
Do not use a network or shared drive.
My media server is on freeNAS, which is inherently network drive.
Does this note actually mean:
“Do not choose a drive which requires network access
with respect to the location of the media server location”?
Restart the jail or server after change the transcode temp directory?
[Someone said: No.]
Hardware: CPU
• CPU : Intel Xeon E3-1231 v3 @ 3.40GHz [passmark: 9626]
Is this too slow?
[Passmark 6000+ should run 3+ 1080p streams.]
Hardware: RAM
• RAM : 16 [GB]
• Test file: 19 [GB]. 1080p. .mkv.
Does RAM need to be greater than media file size?
[Someone said: No.]
Hardware: Interfaces
• ISP ––wire–– WAP[router] ––wifi–– WAP[bridge] ––wire–– server (plex media server)
––wifi–– roku 3 (plex app)
Is this setup a problem?
[Other streaming services (netflix/hulu) have no issues with playback.]
[I assume it’s not.]
