Transcoded files stuck in Transcode directory
Server Version#: 1.25.0.5246
Player Version#: Unknown
I’m noticing that Plex isn’t cleaning up the Transcode directory every time, and it’s leaving large mkv files (output.mkv) in there long after people have stopped watching a movie. I notice this because I get an error like “you don’t have enough free space to transcode this file”, and then I check my Plex transcode directory (RAM drive on Unraid) and it’s almost full with a single Session folder and a single transcoded file.
Once I manually delete the Session folder, everything returns to normal.
I’m having a similar/related problem with the Transcode directory.
No matter what directory I specify in Transcoder temporary directory (I am trying to use /mnt/ssd/plex-transcode), Plex still uses /tmp/Transcode. The directory eventually fills up, and gives me (and anyone trying to stream) the same “you don’t have enough free space to transcode this file”. I have to restart PMS to make everything right again. This most recent time I was camping 1.5 hours from home, so that was fun.
I tried sym-linking /tmp/Transcode to point to my plex-transcode directory, but then the transcoder exits prematurely with an error (no transcoding at all).
Why have an option to provide a temporary directory if you’re not going to use it?
@tinycheese
None of the Plex configurations use /tmp/transcode of the physical device.
Are you using a docker container ?
Straight up Arch actually… 5.10.56-1-lts
Cannot help you.
We do not package for nor support Arch.
Contact the package maintainer.
My problem turned out to be a basic Linux permissions issue …
/mnt/ssd/ had permissions root:sddaccess, which I had set up for access to the secondary drive.
Once I added the plex user to group sddaccess everything is running smoothly again.
Package maintainer had no issues modifying the Transcoder temporary directory so this one was all on me. sigh
