Ill spend an hour curating a playlist with smart filters for different genres of music, if it has more than a couple days worth of music they will just fail to load. this is the 4th time its happened and its getting super old. Is this program not to help users enjoy their own collections? Please fix your program!
Would you mind sharing some specifics?
e.g. what are your filters, does the smart playlist also fail to load on other clients, what error message will Plexamp show when it’s failing to load the playlist?
My biggest smart playlist contains >8 days of music and loads without fail. So the duration alone doesn’t seem to be what’s causing this.
Also… which version of Plexamp are you running and on what platform?
