Smart Playlist Download Bug
Hi all, not sure this is the right section, couldn’t find one for bugs. Anyway, I have found that I (and some others on reddit Reddit - The heart of the internet) are having an issue with downloading smart playlists, when downloading a large smart playlist over like 90 songs it works fine but then when downloading smaller playlists it will only download the first 17-20 songs and randomly stop. All songs are tagged properly and it didn’t do this before. Here are the debug files.
149887407661415.zip (1.4 MB)
Please kill and restart the app; then long press and select Refresh for the playlist item in downloads which is not downloading; then post Plexamp logs.
First, though, long press and select Edit and make sure your download limit isn’t set too low.
Thank you, this worked!
For anyone else:
-Download the smart playlist (even if it doesn’t download all the songs)
  • edit and adjust the download limit to maximum (even if it shows max just drag it all the way to the right and it should work)
  • refresh and the rest should download
  • same for each playlist
