Whenever I try to seek, the app crashes and asks if I want to send a crash report.
Also any show I play using direct play it will pause every minute or so. Sometimes the pause is less than a second. Other times the pause is a good 4-5 seconds. Doesn’t matter what I’m playing.
Using Mi Box. I have two of them and this happens on both units. I’m on latest release as of this posting. I always check for an update before I use Plex.
Server: 1.9.7.4460
This has been happening for awhile now and I waited to see if an update would fix it but it looks like it’s not being fixed so that’s why I posted here.
@kegobeer-plex said:
The navigation crash was fixed with the .2813 beta release. If you still have .2787 make sure you check for an update.
Looks like it has. I went to check my version and saw an update available so I updated. Went from .2787 to .2813. Tested it out and now it’s seeking perfectly fine. The pausing seemed to stop as well. This update must have just hit today because I checked for updates this morning and nothing.
