This discussion was created from comments split from: A new life for PlexConnect.
Hi Guys I have been force recently to update my atv and now seems not not be working the plexconnect on trailers. have any of you sort this out?
Thanks in advance
Latest APTV3 V. 7.2.2 (8015)
A firmware update removes certs from the ATV. You need to reload them (process described in Q9 in the FAQ)
Also it is suggested that you use PlexConnect V0.6, the latest stable version.
@moody_blue said:
A firmware update removes certs from the ATV. You need to reload them (process described in Q9 in the FAQ)Also it is suggested that you use PlexConnect V0.6, the latest stable version.
Thanks for your reply. I’ll try again and let you know if this works.
HI, I have re-set the plexconnect and it works as it use to, Thanks for your support.
another question will this setup will work with PLex DVR? or the Channels?/
Channels are working in V0.6.
Plex DVR, or better said, the ability to schedule TV recordings, is not in plan for PlexConnect. Neither Live TV.
