LG B6 direct plays all HDR HEVC 4K I have except one when using SRT subtitles
Server Version#: 1.23.3.4707
Player Version#: 5.18.1
Platform Version: 3.4.0
TV: webOS OLED55B6V
My LG 4K B6 plays everything except A quiet place part II when subsitles are on, subtiles are on SR and external file. Other 4K HEVC I can play through direct play, not this one:
Media:
  • Duration 1:37:01
  • Bitrate 15179 kbps
  • Width 3840
  • Height 1606
  • Aspect Ratio 2.35
  • Video Resolution 4K
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile main 10
  • Duration 1:37:01
  • File A.Quiet.Place.Part.II.2020.2160p.WEB-DL.DDP5.1.Atmos.HDR.HEVC-CMRG.mkv
  • Size 10.29 GB
  • Container MKV
  • Codec HEVC
  • Bit Depth 10
  • Chroma Subsampling 4:2:0
  • Coded Height 1608
  • Coded Width 3840
  • Color Primaries bt2020
  • Color Range tv
  • Color Space bt2020nc
  • Color Trc smpte2084
  • Frame Rate 23.97599983215332 fps
  • Height 1606
  • Nível 5.0
  • Perfil main 10
  • Ref Frames 1
  • Width 3840
  • Display Title 4K (HEVC Main 10 HDR)
  • Extended Display Title 4K (HEVC Main 10 HDR)
  • Codec EAC3
  • Canais 6
  • Bitrate 768 kbps
  • Idioma English
  • Audio Channel Layout 5.1(side)
  • Sampling Rate 48000 Hz
  • Título English
  • Display Title English (EAC3 5.1)
  • Extended Display Title English (EAC3 5.1)
I believe your TV does not support Atmos
Thanks for the reply, but then how does it work without subtitles ?
When audio is transcoding and subtitles have been enabled, the video will be forced to transcode.
Here’s a better explanation of how subtitles and video transcoding works with the LG app: Is it normal for a movie to require 295mb/s speed? No wonder is buffering - #3 by FordGuy61
Thanks so much for the reply, do you think I’ll have any alternative to watch ATMOS releases with subtitles ? Can I somehow use plex to pre-convert the audio to something different as a new audio track ?
You can optimize the video file.
