LG C9 TV: Conversion failed. The transcoder exited due to an error happening occasionally
Server Version#: 1.30.0.6359
Player Version#: Latest
Hi all,
So, I’ve got everything setup on my LG C9 Plex App to directplay (as well as in the server to allow directplay and directstream), to always use unsecure connection, burn subtitles: never, etc.
It has always direct played everything I have. MKVs, MP4s, 4K Remuxes, etc. But lately, in the last couple of months I’ve been randomly getting this Conversion failed. The transcoder exited due to an error.
I’m not sure if this is related to PGS now being able to be direct played? I’ve noticed on a specific TV show I’m watching that PGS subs just stop displaying until I restart playback but on movies etc it’s absolutely fine. The conversion failed issue happens completely randomly, all I have to do is press OK then play the file again. Sometimes it happens 2-3x per movie/tv show, sometimes none. I can’t seem to pinpoint any specific reason.
My server is an odroid n2+, so 0 transcoding power. Anything that has changed recently? Or anything anyone can point out?
Thanks!
Haven’t seen this issue on my LG C1 Plex app.
All I can suggest is having a look at your logs
A few references I found
Nov 09, 2022 23:57:50.586 [0xffff9d40faa0] DEBUG - Request: [192.168.1.193:36234 (WAN)] GET /library/metadata/14884?includeUserState=1&checkFiles=1&asyncAugmentMetadata=1 (9 live) #ee637 GZIP Signed-in Token (Sptz87) (LG OLED55C9PLA)
Nov 09, 2022 23:57:50.590 [0xffff9d20caa0] DEBUG - [Req#ee6a0] Setting container serialization range to [0, 119] (total=-1)
Nov 09, 2022 23:57:50.597 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: Selected protocol hls; container: mpegts
Nov 09, 2022 23:57:50.597 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: analyzing media item 23818
Nov 09, 2022 23:57:50.597 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: Direct Play is disabled
Nov 09, 2022 23:57:50.597 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: media must be transcoded in order to use the hls protocol
Nov 09, 2022 23:57:50.597 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: no direct play music profile exists for http/mp3/mp3
Nov 09, 2022 23:57:50.598 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: selected media 0 / 23818
Nov 09, 2022 23:57:50.598 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] Streaming Resource: Calculated bandwidth of 672kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 320kbps
Nov 09, 2022 23:57:50.598 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Nov 09, 2022 23:57:50.603 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] Streaming Resource: Reducing playback quality for 304kbps stream bitrate: disable audio DS as 2147483647kbps is > the 304kbps available
Nov 09, 2022 23:57:50.604 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: Selected protocol hls; container: mpegts
Nov 09, 2022 23:57:50.604 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: analyzing media item 23818
Nov 09, 2022 23:57:50.604 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: Direct Play is disabled
Nov 09, 2022 23:57:50.604 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: media must be transcoded in order to use the hls protocol
Nov 09, 2022 23:57:50.604 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: no direct play music profile exists for http/mp3/mp3
Nov 09, 2022 23:57:50.604 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Nov 09, 2022 23:57:50.605 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: Cannot direct stream audio stream due to profile or setting limitations
Nov 09, 2022 23:57:50.605 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] MDE: tv.plex.agents: selected media 0 / 23818
Nov 09, 2022 23:57:50.610 [0xffff9d20caa0] DEBUG - [Req#ee6a0] Setting container serialization range to [0, 119] (total=10)
Nov 09, 2022 23:57:50.612 [0xffff9f83aaa0] DEBUG - [Req#ee696/Transcode] Streaming Resource: Reached Decision id=14983 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=23818 part=(id=26909 decision=transcode protocol=hls streams=(Audio=(id=105629 decision=transcode bitrate=258 encoder=aac channels=2 rate=44100))))
Directplay is disabled??! What? This is just a regular 1080p mkv file o_O
Nov 10, 2022 00:09:19.526 [0xffff9ec28aa0] DEBUG - Streaming Resource: Terminated session 0xffffa6d001d8:kq24vhwz8mug6m4r5dooh7rp with reason Conversion failed. The transcoder exited due to an error.
Nov 10, 2022 00:09:19.526 [0xffff9ec28aa0] DEBUG - Cleaning directory for session 44hekqmsccr6lt76deipvh8m (/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-44hekqmsccr6lt76deipvh8m-59884c9d-f146-4499-a3b8-c14a56bba150)
Nov 10, 2022 00:09:19.554 [0xffffa8493aa0] ERROR - [TranscodeOutputStream] Session appears to have died from under us
Nov 10, 2022 00:09:19.608 [0xffffa8290aa0] ERROR - Session 0xffffa6d001d8 terminated
Nov 10, 2022 00:09:19.693 [0xffffa36dfaa0] DEBUG - Request: [192.168.1.193:36662 (WAN)] GET /library/parts/26821/1659538948/file.mkv?Accept=application%2Fjson&Accept-Language=en-GB (5 live) #10884b Signed-in Token (Sptz87) (LG OLED55C9PLA) (range: bytes=2950846363-)
Nov 10, 2022 00:09:19.811 [0xffffa36dfaa0] WARN - [Req#10884b] Denying access to direct play of part 26821 due to terminated session
Nov 10, 2022 00:09:19.811 [0xffffa8290aa0] DEBUG - Completed: [192.168.1.193:36662] 503 GET /library/parts/26821/1659538948/file.mkv?Accept=application%2Fjson&Accept-Language=en-GB (5 live) 118ms 290 bytes (range: bytes=2950846363-)
Nov 10, 2022 00:09:19.839 [0xffff9d612aa0] DEBUG - Request: [192.168.1.193:36664 (WAN)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F14887&ratingKey=14887&state=stopped&time=690406&duration=1716683&playbackTime=673636&playQueueItemID=53794&context=home%3Ahub.continueWatching&row=0&col=1&continuing=1 (5 live) #10885b GZIP Signed-in Token (Sptz87) (LG OLED55C9PLA)
Nov 10, 2022 00:09:19.842 [0xffff9d612aa0] DEBUG - [Req#10885b] Client [kq24vhwz8mug6m4r5dooh7rp] reporting timeline state stopped, progress of 690406/1716683ms for guid=, playbackTime=673636ms ratingKey=14887 url=, key=/library/metadata/14887, containerKey=, metadataId=14887, source=
Nov 10, 2022 00:09:19.859 [0xffff9d612aa0] DEBUG - [Req#10885b] Play progress on 14887 'The Vic Allen Dinner' - got played 690406 ms by account 1!
Nov 10, 2022 00:09:19.897 [0xffff9d612aa0] DEBUG - [Req#10885b] [Now] User is Sptz87 (ID: 1)
Nov 10, 2022 00:09:19.897 [0xffff9d612aa0] DEBUG - [Req#10885b] [Now] Device is webOS (LG OLED55C9PLA).
Nov 10, 2022 00:09:19.915 [0xffff9d612aa0] ERROR - [Req#10885b] Unable to find client profile for device; platform=webOS, platformVersion=4.9.0, device=webOS 4.9.0, model=OLED55C9PLA
Nov 10, 2022 00:09:19.915 [0xffff9d612aa0] DEBUG - [Req#10885b] [Now] Updated play state for /library/metadata/14887.
Nov 10, 2022 00:09:19.918 [0xffff9d612aa0] DEBUG - [Req#10885b] Statistics: (kq24vhwz8mug6m4r5dooh7rp) Reporting active playback in state 3 of type 4 (scrobble: 0) for account 1
Nov 10, 2022 00:09:19.921 [0xffff9d612aa0] DEBUG - [Req#10885b] Cleaning directory for session 44hekqmsccr6lt76deipvh8m (/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-44hekqmsccr6lt76deipvh8m-6a9baaca-e054-43b4-b757-5b8d8025a9ff)
Nov 10, 2022 00:09:19.925 [0xffffa8290aa0] DEBUG - Completed: [192.168.1.193:36664] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F14887&ratingKey=14887&state=stopped&time=690406&duration=1716683&playbackTime=673636&playQueueItemID=53794&context=home%3Ahub.continueWatching&row=0&col=1&continuing=1 (5 live) GZIP 85ms 679 bytes (pipelined: 1)
Nov 10, 2022 00:09:19.972 [0xffffa286aaa0] DEBUG - Request: [172.18.0.1:45812 (Subnet)] GET /library/metadata/14887 (6 live) #10885d GZIP Signed-in Token (Sptz87) (n2server (Tautulli))
Nov 10, 2022 00:09:19.993 [0xffffa286aaa0] DEBUG - [Req#10885d] We're going to try to auto-select an audio stream for account 1.
Nov 10, 2022 00:09:19.993 [0xffffa286aaa0] DEBUG - [Req#10885d] Selecting best audio stream for part ID 26821 (autoselect: 1 language: en)
Nov 10, 2022 00:09:19.993 [0xffffa286aaa0] DEBUG - [Req#10885d] We're going to try to auto-select a subtitle.
Nov 10, 2022 00:09:19.993 [0xffffa286aaa0] DEBUG - [Req#10885d] Subtitles: Found a candidate subtitle language [en] for a foreign film
Nov 10, 2022 00:09:19.993 [0xffffa286aaa0] DEBUG - [Req#10885d] Audio Stream: 105047, Subtitle Stream: 105048
Nov 10, 2022 00:09:20.000 [0xffffa8290aa0] DEBUG - Completed: [172.18.0.1:45812] 200 GET /library/metadata/14887 (6 live) GZIP 28ms 2711 bytes (pipelined: 1)
Nov 10, 2022 00:09:20.023 [0xffffa0a3daa0] DEBUG - Request: [172.18.0.1:45812 (Subnet)] GET /library/metadata/14871 (6 live) #108867 GZIP Signed-in Token (Sptz87) (n2server (Tautulli))
Nov 10, 2022 00:09:20.115 [0xffffa0a3daa0] DEBUG - [Req#108867] It took 80.000000 ms to retrieve 212 items.
Nov 10, 2022 00:09:20.140 [0xffffa0a3daa0] DEBUG - [Req#108867] It took 30.000000 ms to retrieve 212 items.
Nov 10, 2022 00:09:20.353 [0xffffa0a3daa0] DEBUG - [Req#108867] There were 1 top-level paths for Veep.
Nov 10, 2022 00:09:20.359 [0xffffa8290aa0] DEBUG - Completed: [172.18.0.1:45812] 200 GET /library/metadata/14871 (6 live) GZIP 335ms 11241 bytes (pipelined: 2)
Nov 10, 2022 00:09:20.399 [0xffff9ce06aa0] DEBUG - Request: [172.18.0.1:45812 (Subnet)] GET /library/metadata/14883 (6 live) #108868 GZIP Signed-in Token (Sptz87) (n2server (Tautulli))
Nov 10, 2022 00:09:20.439 [0xffffa8290aa0] DEBUG - Completed: [172.18.0.1:45812] 200 GET /library/metadata/14883 (6 live) GZIP 39ms 877 bytes (pipelined: 3)
Nov 10, 2022 00:09:20.446 [0xffff9d20caa0] DEBUG - Request: [172.18.0.1:45812 (Subnet)] GET /library/metadata/14871 (6 live) #108869 GZIP Signed-in Token (Sptz87) (n2server (Tautulli))
Nov 10, 2022 00:09:20.455 [0xffff9d20caa0] DEBUG - [Req#108869] It took 10.000000 ms to retrieve 212 items.
Nov 10, 2022 00:09:20.466 [0xffff9d20caa0] DEBUG - [Req#108869] It took 10.000000 ms to retrieve 212 items.
Nov 10, 2022 00:09:20.472 [0xffff9d20caa0] DEBUG - [Req#108869] There were 1 top-level paths for Veep.
Nov 10, 2022 00:09:20.477 [0xffffa8290aa0] DEBUG - Completed: [172.18.0.1:45812] 200 GET /library/metadata/14871 (6 live) GZIP 31ms 11241 bytes (pipelined: 4)
Nov 10, 2022 00:09:21.952 [0xffffa286aaa0] DEBUG - Request: [192.168.1.193:36664 (WAN)] GET /subtitles/:/transcode/universal/start?Accept=application%2Fjson&Accept-Language=en-GB&directPlay=1&directStream=1&directStreamAudio=1&protocol=http&fastSeek=1&path=%2Flibrary%2Fmetadata%2F14887&session=44hekqmsccr6lt76deipvh8m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=75&videoQuality=100&videoResolution=3840x2160&audioBoost=100&subtitles=sidecar&location=lan&copyts=1&offset=690 (5 live) #108865 GZIP Signed-in Token (Sptz87) (LG OLED55C9PLA)
Nov 10, 2022 00:09:21.952 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode] Found session GUID of 44hekqmsccr6lt76deipvh8m in session start.
Nov 10, 2022 00:09:21.952 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-transcode-target(type=videoProfile&context=streaming&protocol=hls&container=mpegts&videoCodec=h264,hevc,mpeg2video,mpeg4&audioCodec=aac,ac3,eac3,mp2,mp3)+add-limitation(scope=videoAudioCodec&scopeName=mp2&type=upperBound&name=audio.bitrate&value=350)+add-limitation(scope=videoAudioCodec&scopeName=mp3&type=upperBound&name=audio.bitrate&value=350)+add-limitation(scope=videoCodec&scopeName=h264&type=upperBound&name=video.level&value=51)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=3840)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=10)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=3840)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=1920)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=1080)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=1920)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=1080)+add-transcode-target(type=subtitleProfile&protocol=http&context=all&subtitleCodec=srt&container=srt)
Nov 10, 2022 00:09:21.953 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode] TranscodeUniversalRequest: using augmented profile Generic
Nov 10, 2022 00:09:21.953 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/14887?checkFiles=1&includeBandwidths=1&offset=690&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=kq24vhwz8mug6m4r5dooh7rp
Nov 10, 2022 00:09:21.981 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode/Req#10886c] We're going to try to auto-select an audio stream for account 1.
Nov 10, 2022 00:09:21.982 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode/Req#10886c] Selecting best audio stream for part ID 26821 (autoselect: 1 language: en)
Nov 10, 2022 00:09:21.982 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode/Req#10886c] We're going to try to auto-select a subtitle.
Nov 10, 2022 00:09:21.982 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode/Req#10886c] Subtitles: Found a candidate subtitle language [en] for a foreign film
Nov 10, 2022 00:09:21.982 [0xffffa286aaa0] DEBUG - [Req#108865/Transcode/Req#10886c] Audio Stream: 105047, Subtitle Stream: 105048
Nov 09, 2022 23:58:02.410 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] TranscodeUniversalRequest: using augmented profile Generic
Nov 09, 2022 23:58:02.410 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/14887?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=kq24vhwz8mug6m4r5dooh7rp
Nov 09, 2022 23:58:02.426 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode/Req#ee837] We're going to try to auto-select an audio stream for account 1.
Nov 09, 2022 23:58:02.426 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode/Req#ee837] Selecting best audio stream for part ID 26821 (autoselect: 1 language: en)
Nov 09, 2022 23:58:02.426 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode/Req#ee837] We're going to try to auto-select a subtitle.
Nov 09, 2022 23:58:02.426 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode/Req#ee837] Subtitles: Found a candidate subtitle language [en] for a foreign film
Nov 09, 2022 23:58:02.426 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode/Req#ee837] Audio Stream: 105047, Subtitle Stream: 105048
Nov 09, 2022 23:58:02.442 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] MDE: Selected protocol http; container: srt
Nov 09, 2022 23:58:02.442 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] MDE: analyzing media item 23730
Nov 09, 2022 23:58:02.443 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] MDE: E4 - The Vic Allen Dinner: no direct play video profile exists for http/mkv/h264
Nov 09, 2022 23:58:02.443 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] MDE: E4 - The Vic Allen Dinner: no direct play video profile exists for http/mkv/h264/dca
Nov 09, 2022 23:58:02.443 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] MDE: E4 - The Vic Allen Dinner: transcoding selected subtitle stream
Nov 09, 2022 23:58:02.443 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] MDE: Veep - S2 E4 - The Vic Allen Dinner: selected media 0 / 23730
Nov 09, 2022 23:58:02.443 [0xffff9ea25aa0] DEBUG - [Req#ee836/Transcode] Killing job.
Nov 09, 2022 23:58:02.443 [0xffff9ea25aa0] DEBUG - [Req#ee836/Transcode] Signalling job ID 5781 with 9
Nov 09, 2022 23:58:02.443 [0xffff9ea25aa0] DEBUG - [Req#ee836/Transcode] Job was already killed, not killing again.
Nov 09, 2022 23:58:02.443 [0xffff9ea25aa0] DEBUG - [Req#ee836/Transcode] Stopping transcode session jof7kblufj9u17d2gfh42rap
Nov 09, 2022 23:58:02.443 [0xffff9f434aa0] DEBUG - [Req#ee836/Transcode] Cleaning directory for session jof7kblufj9u17d2gfh42rap (/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-jof7kblufj9u17d2gfh42rap-540a1262-6939-44f8-9f26-77a800d3c800)
Nov 09, 2022 23:58:02.445 [0xffff9ea25aa0] DEBUG - [Req#ee836/Transcode] Whacked session jof7kblufj9u17d2gfh42rap, 2 remaining.
Nov 09, 2022 23:58:02.445 [0xffff9ea25aa0] DEBUG - Cleaning directory for session jof7kblufj9u17d2gfh42rap (/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-jof7kblufj9u17d2gfh42rap-540a1262-6939-44f8-9f26-77a800d3c800)
Nov 09, 2022 23:58:02.455 [0xffff9ce06aa0] DEBUG - [Req#ee832/Transcode/kzh3phuz6ndgskoi60c6q6zj/db80a4a1-b740-4e55-bec4-a66cd680277a] Transcoder segment range: 0 - 81 (81)
Nov 09, 2022 23:58:02.456 [0xffff9ca00aa0] DEBUG - [Req#ee83d/Transcode/kzh3phuz6ndgskoi60c6q6zj/db80a4a1-b740-4e55-bec4-a66cd680277a] Transcoder segment range: 0 - 82 (81)
Nov 09, 2022 23:58:02.457 [0xffffa36dfaa0] DEBUG - [Req#ee836/Transcode] Streaming Resource: Reached Decision id=14887 codes=(MDE=1000,Direct play OK.) media=(id=23730 part=(id=26821 decision=direct play protocol=hls streams=(Video=(id=105046 decision= width=1920 height=1080) Audio=(id=105047 decision= channels=0 rate=0) Subtitle=(id=105048 decision=copy languageCode=eng location=sidecar))))
Nov 09, 2022 23:58:02.458 [0xffffa8290aa0] DEBUG - Completed: [192.168.1.193:36228] 200 GET /video/:/transcode/universal/decision?directPlay=1&directStream=1&directStreamAudio=1&protocol=hls&fastSeek=1&path=%2Flibrary%2Fmetadata%2F14887&session=44hekqmsccr6lt76deipvh8m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=75&videoQuality=100&videoResolution=3840x2160&audioBoost=100&subtitles=sidecar&location=lan (9 live) GZIP 48ms 2517 bytes (pipelined: 19)
Nov 09, 2022 23:58:02.521 [0xffff9d40faa0] DEBUG - Request: [192.168.1.193:36228 (WAN)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F14887&ratingKey=14887&state=buffering&time=0&duration=1716683&playbackTime=0&playQueueItemID=53794&context=home%3Ahub.continueWatching&row=0&col=1 (9 live) #ee841 GZIP Signed-in Token (Sptz87) (LG OLED55C9PLA)
Nov 09, 2022 23:58:02.522 [0xffff9d40faa0] DEBUG - [Req#ee841] Client [kq24vhwz8mug6m4r5dooh7rp] reporting timeline state buffering, progress of 0/1716683ms for guid=, playbackTime=0ms ratingKey=14887 url=, key=/library/metadata/14887, containerKey=, metadataId=14887, source=
Nov 09, 2022 23:58:02.531 [0xffff9d40faa0] DEBUG - [Req#ee841] We're going to try to auto-select an audio stream for account 1.
Nov 09, 2022 23:58:02.531 [0xffff9d40faa0] DEBUG - [Req#ee841] Selecting best audio stream for part ID 26821 (autoselect: 1 language: en)
Nov 09, 2022 23:58:02.531 [0xffff9d40faa0] DEBUG - [Req#ee841] We're going to try to auto-select a subtitle.
Nov 09, 2022 23:58:02.531 [0xffff9d40faa0] DEBUG - [Req#ee841] Subtitles: Found a candidate subtitle language [en] for a foreign film
Nov 09, 2022 23:58:02.531 [0xffff9d40faa0] DEBUG - [Req#ee841] Audio Stream: 105047, Subtitle Stream: 105048
Nov 09, 2022 23:58:02.537 [0xffff9d40faa0] DEBUG - [Req#ee841] [Now] User is Sptz87 (ID: 1)
Nov 09, 2022 23:58:02.537 [0xffff9d40faa0] DEBUG - [Req#ee841] [Now] Device is webOS (LG OLED55C9PLA).
Nov 09, 2022 23:58:02.537 [0xffff9d40faa0] DEBUG - [Req#ee841] [Now] Profile is Generic
Nov 09, 2022 23:58:02.537 [0xffff9d40faa0] DEBUG - [Req#ee841] [Now] Updated play state for /library/metadata/14887.
Nov 09, 2022 23:58:02.537 [0xffff9d40faa0] DEBUG - [Req#ee841] Statistics: (kq24vhwz8mug6m4r5dooh7rp) Reporting active playback in state 2 of type 4 (scrobble: 0) for account 1
Nov 09, 2022 23:58:02.540 [0xffff9f231aa0] DEBUG - [Req#ee841] Killing job.
Nov 09, 2022 23:58:02.540 [0xffff9f231aa0] DEBUG - [Req#ee841] Signalling job ID 5776 with 9
Nov 09, 2022 23:58:02.540 [0xffff9f231aa0] DEBUG - [Req#ee841] Job was already killed, not killing again.
Nov 09, 2022 23:58:02.540 [0xffff9f231aa0] DEBUG - [Req#ee841] Stopping transcode session kzh3phuz6ndgskoi60c6q6zj
I don’t really know where to start or stop pasting the logs but what I do know is that I’ve always seen Direct Play in the servers dashboard
How about sharing the entire ZIP file please ? :sunglasses:
That allows us to look at everything leading to the conversion decision and if it was correct or not
Plex Media Server Logs_2022-11-11_00-37-04.zip (5.4 MB)
Here you go ^^
Thanks for this.
The app might have blamed a transcoder failure but the app is the problem.
(those silly app guys… LOL)
Nov 10, 2022 18:21:22.713 [0xffff9cf48aa0] DEBUG - [Req#1a8712] [Now] Updated play state for /library/metadata/14951.
Nov 10, 2022 18:21:22.713 [0xffff9cf48aa0] DEBUG - [Req#1a8712] Statistics: (kq24vhwz8mug6m4r5dooh7rp) Reporting active playback in state 0 of type 4 (scrobble: 0) for account 1
Nov 10, 2022 18:21:22.718 [0xffffa8493aa0] DEBUG - Completed: [192.168.1.193:50118] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F14951&ratingKey=14951&state=playing&time=864117&duration=2878944&playbackTime=936479&playQueueItemID=53922&timeStalled=0 (7 live) GZIP 8ms 848 bytes (pipelined: 3)
Nov 10, 2022 18:21:22.941 [0xffffa1249aa0] DEBUG - Request: [192.168.1.193:50118 (WAN)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F14951&ratingKey=14951&state=playing&time=894117&duration=2878944&playbackTime=936717&playQueueItemID=53922 (7 live) #1a871a GZIP Signed-in Token (Sptz87) (LG OLED55C9PLA)
Nov 10, 2022 18:21:22.943 [0xffffa1249aa0] DEBUG - [Req#1a871a] Client [kq24vhwz8mug6m4r5dooh7rp] reporting timeline state playing, progress of 894117/2878944ms for guid=, playbackTime=936717ms ratingKey=14951 url=, key=/library/metadata/14951, containerKey=, metadataId=14951, source=
Nov 10, 2022 18:21:22.945 [0xffffa1249aa0] DEBUG - [Req#1a871a] Play progress on 14951 'The Jet Set' - got played 894117 ms by account 1!
Nov 10, 2022 18:21:22.946 [0xffffa8493aa0] DEBUG - Failed to stream media, client probably disconnected after 42705864 bytes: 104 - Connection reset by peer
Nov 10, 2022 18:21:22.946 [0xffffa8493aa0] DEBUG - Completed after connection close: [192.168.1.193:50116] 206 GET /library/parts/26878/1593119443/file.mkv?Accept=application%2Fjson&Accept-Language=en-GB (7 live) 1163ms 42705864 bytes (range: bytes=2316978925-)
Nov 10, 2022 18:21:22.948 [0xffff9cf48aa0] DEBUG - Request: [192.168.1.193:50120 (WAN)] GET /library/parts/26878/1593119443/file.mkv?Accept=application%2Fjson&Accept-Language=en-GB (7 live) #1a8713 Signed-in Token (Sptz87) (LG OLED55C9PLA) (range: bytes=2415332937-)
Nov 10, 2022 18:21:22.950 [0xffffa1249aa0] DEBUG - [Req#1a871a] [Now] User is Sptz87 (ID: 1)
Nov 10, 2022 18:21:22.950 [0xffffa1249aa0] DEBUG - [Req#1a871a] [Now] Device is webOS (LG OLED55C9PLA).
Nov 10, 2022 18:21:22.950 [0xffffa1249aa0] DEBUG - [Req#1a871a] [Now] Profile is Generic
The OLED TV app disconnected quite a ways into the playback
We’ll need to recreate this again and grab the Player app logs.
I do have a question about your networking.
192.168.1.147 is considered WAN (on a different subnet) from the server ?
Nov 10, 2022 18:06:35.101 [0xffff9cf48aa0] DEBUG - [Req#1a7e6d/Transcode/leomatytc9d88r9r8d4a6k9c/c7129f4e-846a-4986-9d39-f715d2f7766f] Transcoder segment range: 0 - 1078 (1077)
Nov 10, 2022 18:06:35.252 [0xffff9ed42aa0] DEBUG - [Req#1a7e71/Transcode/leomatytc9d88r9r8d4a6k9c/c7129f4e-846a-4986-9d39-f715d2f7766f] Transcoder segment range: 0 - 1078 (1078)
Nov 10, 2022 18:06:35.256 [0xffff9d34eaa0] DEBUG - [Req#1a7e74/Transcode/leomatytc9d88r9r8d4a6k9c/c7129f4e-846a-4986-9d39-f715d2f7766f] Transcoder segment range: 0 - 1079 (1078)
Nov 10, 2022 18:06:35.313 [0xffff9dd92aa0] DEBUG - Request: [192.168.1.147:55158 (WAN)] GET /:/prefs (13 live) #1a7e29 TLS GZIP Signed-in Token (Sptz87) (Microsoft Edge)
Nov 10, 2022 18:06:35.313 [0xffff9df95aa0] DEBUG - Request: [192.168.1.147:55156 (WAN)] GET /accounts/1 (13 live) #1a7e2a TLS GZIP Signed-in Token (Sptz87) (Microsoft Edge)
Nov 10, 2022 18:06:35.314 [0xffff9cf48aa0] DEBUG - Request: [192.168.1.147:55155 (WAN)] GET /myplex/account (13 live) #1a7e32 TLS GZIP Signed-in Token (Sptz87) (Microsoft Edge)
Nov 10, 2022 18:06:35.314 [0xffff9ed42aa0] DEBUG - Request: [192.168.1.147:55154 (WAN)] GET /system/:/prefs (13 live) #1a7e39 TLS GZIP Signed-in Token (Sptz87) (Microsoft Edge)
Nov 10, 2022 18:06:35.315 [0xffff9ed42aa0] DEBUG - [Req#1a7e39] [com.plexapp.system] Sending command over HTTP (GET): /system/:/prefs
Nov 10, 2022 18:06:35.315 [0xffff9ed42aa0] DEBUG - [Req#1a7e39/HCl#db2] HTTP requesting GET http://127.0.0.1:38593/system/:/prefs
Nov 10, 2022 18:06:35.315 [0xffffa8493aa0] DEBUG - Completed: [192.168.1.147:55156] 200 GET /accounts/1 (13 live) TLS GZIP 2ms 644 bytes (p
Thanks for taking a look!
The OLED TV is connected with ethernet, both the server and TV are connected to 1GBps LAN. I’ve never had buffer issues with huge bitrate remuxes etc. There was really never an issue before as I’ve stated in OP.
Regarding that IP, that IP is my main laptop that’s connected to WIFI, was probably me testing with the Plex App on Windows but it makes no sense to be recognized as WAN? I do have an AI MESH setup, 2x routers. The laptop is connected to the second router for stronger signal but AI MESH is supposedly just an “extender” with user friendly config.
How do I get the player app logs?
https://support.plex.tv/articles/216955788-logging-for-smart-tvs-tivo/
I have the same problem. It started a few weeks or or maybe months ago.
I have video transcoding disabled on the server, so the error message doesn’t make any sense at all. I always direct play all files that I have on the server.
For me, the error never happens when I “normally” watch a file. But if I jump around a bit in a file, e.g. a few times forward and backward and forward again, then there is a chance that after a few seconds the error message is shown.
After the error happens and I’m back at the pre-play screen I can immediately resume the file at the error position without additional errors (unless I start jumping around in the timeline again).
Nearly all of my files are MKVs, so I can only confirm the error for MKV files. The error happens for both for 1080p and 4k files. I’m not 100% sure right now about subtitles and HDR, but I think it also happens both with and without HDR and with and without (SRT) subtitles.
Everything is connected locally via gigabit ethernet cables. Nothing else has network problems. Plex was stable until a few weeks or maybe months ago.
Here are my player logs: Plex Media Server Logs_2022-11-13_10-14-03.zip (342.0 KB)
In that log the error happend in a MKV file with (non-HDR) 1080p H.264 video, EAC3 audio and SRT subtitles.
The relevant part seems to be [Player] A critical HTML media error occurred: 2 (Netzwerk); the player cannot recover here:
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] ERROR - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] [Subtitles: Connection Monitor] An unknown error ocurred:
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] INFO - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] [Subtitles: XHR] Aborting current connection (Total 0 bytes downloaded).
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] INFO - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] [Subtitles: Connection] Opening connection at offset 1238892
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] WARN - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] [Player] A critical HTML media error occurred: 2 (Netzwerk); the player cannot recover
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] INFO - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] [PlaybackSessionController] playback state changed to: stopped
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] ERROR - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] [Subtitles: Connection Monitor] An unknown error ocurred: <html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] ERROR - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] Playback error occurred. Reason: ServerTerminatedStream, Server terminated stream: Konvertierung fehlgeschlagen. Der Transcoder wurde aufgrund eines Fehlers beendet.
Nov 13, 2022 10:12:55.593 [0x7f0b1daabb38] WARN - [Req#b50f] [Plex for LG] [cremor:hn3o5tiz99m0tzx1cji9svgs] [PlaybackSessionController] could not retry, reporting error
Server 1.29.2.6364 on Docker
Plex for LG app 5.49.3 on LG C9 (platform version 4.9.0)
(The problem happend with older server and app versions too.)
@ChuckPa This still happens with Plex for LG app version 5.50.1. Are my logs enough to find the problem?
I just updated my LG C1
App: 5.50.1
Platform: 6.3.1
Not a single issue on a tiny DS418 (ARMv8) even at this bitrate.
Which TV firmware do you have?
I know next-to-nothing about TV firmware but given the issues I had with CEC and ARC on mine, I know firmware is key
Plex app version 5.50.1 (platform 4.9.0)
LG C9 firmware version 05.30.11 (latest available)
The problem might not happen with all media. Or maybe it just happens with subtitles.
If you can make it happen with a specific file, please do so.
  1. Turn DEBUG logging back on. INFO/ERROR logging is useless.
  2. Start the playback
  3. Let it fail
  4. Download the server logs
  5. Attach
@ChuckPa The logs I provided already had the log level at debug because this is the default value in the Plex for LG app.
The problem is that this is completely random. So I’d have to leave it on all the time I guess. Some days it doesn’t happen at all.
Here is an example file (2.89GB) where I see similar issues to those posted, yet in my case I see a spinning circle for 1 to 2 minutes then playback resumes (LG C1).
Perhaps people could download this and try on their servers.
This file contains DVB subtitles (you need to turn off to avoid subtitle burning).
Being TS it must be remuxed
If I keep subtitles on, on my DS418 – it does sit there.
If I turn them off, It takes a few seconds for the Remux to fill the output buffer and start playback ( I get to see the countdown on the BBC timer . lol )
Which CPU is this server running on?
Hi, this is a DVB-T2 recording in the UK from a HDHomeRun.
I don’t display subtitles at all.
My issue occurs if I hit skip forward multiple times in quick succession, for example 4 quick presses to jump 2 minutes - keep trying that and in a few iterations I get the hang, also see it if I use skip adverts button.
I have an Intel Core i5-7500T
I’m unable to test for the issue with your Gods-Testfile.mkv testfile. I can play the file, but seeking or jumping around in it doesn’t work. I’ve tried seeking in the timeline, jumping with left/right buttons and jumping with channel up/down buttons. Nothing works. The timeline shows the target timestamp for a very short time and then just goes back to the current position.
If i skip multiple times in succession, I need press PLAY to continue playback.
I don’t have any other ‘hang’ .
For me, there is the expected 2-3 second spinning circle while the DS418 seeks into the right spot but that’s all I’m able to reproduce with this file.
SIDE NOTE: You footballers are CRAZY! LOL Red cards flying everwhere! LOL
