LG C1 OLED spinning circle for 1 to 2 minutes on multiple skip forwards
Server Version#: 1.29.2.6364
Player Version#:5.50.1
Just wondered if anyone else was seeing this issue? :-
Playing back recorded live TV, if I press the skip forward button a single time everything is fine, skips forward 30 seconds as expected.
If I hit the skip forward button several times, say 4 or 6, in tight succession, then intermittently I will be greeted by a spinning circle for anywhere from 1 to 2 minutes, and then the playback resumes.
Typically every four or five times I do this operation I hit this problem, I have also hit it when clicking the skip adverts button.
ps. this is with a wired connection, also no problems with the same content and skipping on FireTV
No one see this issue?
If you use an LG webos 6 TV and all is good with the built in app please let me know :blush:
Do you also have this problem when you play “normal” media from the server, so not recorded live TV? If yes, this could be related to LG C9 TV: Conversion failed. The transcoder exited due to an error happening occasionally (maybe the C9 aborts playback and the C1 shows the spinning circle?).
Well, after trying a few films I could reproduce the fault yes, but not as easily reproducible as recorded TV.
I will have at look at that thread, thanks!
Using the BluRay I re-ripped for the other thread, I cannot repeat this at all with the 5.50.1 app on WebOS 6.3.1
I’ll try the latest test file you posted and see what happens.
Just to confirm, you couldn’t re-create the issue with my football test file from my DVR ?
Yes, I cannot reproduce the issue on the new gods testfile, your previous one I could.
Problem is, I am hitting this problem on stuff I skip the most on, recorded TV from HDHomeRun :frowning_face:
Conclusion seems to be something the LG App doesn’t like in these files…
I couldn’t reproduce with your file.
The only change I made to the file between original and what works – Run through mkvmerge to rewrite the MKV info block that’s written at EOF.
Bizarre, same TV and firmware.
I’ll grab another sample file if you can check that also.
@e10kstarfire
So what’s the difference?
  1. I have the TV on WiFi , not wired (too slow)
    NETGEAR Wireless Access Point (WAX218PA) - WiFi 6 Dual-Band AX3600 Speed
  2. My server continues to be PMS 1.29.2 on a lowly ARMv8 DS418j :slight_smile:
I’ve connected via WiFi now, router reports approx 500Mbps connection to the TV.
I am running latest public PMS.
Whether connected WiFi or ethernet should not cause the problem I see, we are only talking about 5Mbps stream!
Still seeing this issue, really annoying :angry:
FireTV app is fine, just see this on the LG.
I’m also seeing this issue
Yes unfortunately no further progress, see this on all media randomly
