The location to get tot the subtitle offset is horrible.
I mean there is so much space left on the player controls, why not put it there?
And when you’re actually using it, the slider is above the subtitles on the bottom?
Furthermore, I’ve tried it on multiple episodes and shows with external subtitles but it does not seem to work either.
Sometimes I also get subtitles with a black background? Is this Plex or a problem with the subtitles? I’ve never seen that before unless on live TV.
Seems like some issues should be solved ![]()
I should have the latest version, I’ll check when I get some time in front of the tv.
