LG TV no time skip function
Server Version#: 1.32 synology
Player Version#: 4.4
I have LG webos TV and downloaded Plex client and installed Plex server on Synology D220j. However, I can skip around. No fast-forward 30 seconds or rewind 10 seconds. No jumping to certain time in movie/show. Just play and pause.
Any help is greatly appreciated.
Current version is 5.58.3: Plex for webOS 3.0+ (LG Televisions) - #96 by markus101
Verify version in the Plex app, not in LG app store.
I’ve an LG B7 OLED.
Left and right side of ring on remote are rewind and fast forward.
Press up to move to the progress bar and move forward / backward faster than 10 sec / 30 sec.
Press down to bring up on-screen controls. If media has chapters, can then jump to individual chapter marker.
Z01
hey, looks like solution, but how download that package? can’t find anywhere
Check for updates in the LG app store on the TV. That is the only place to obtain the Plex app for LG TVs (no sideloading like on Android).
then problem still persist, that was mistake, I have 5.1.2 which latest from store
To add the LG B8OLED works the same. If not using chapters just hold down left or right direction key and the Timeline which appears on the OCD like FordGuy61 mentioned with progress forward or backwards.
Process: Press the up button twice a dot will appear on the Timeline, using << or >> you will notice the Dot move and Time indicators will change.
yeap, it works, thanks
